[Mapserver-users] jBox
Richard Greenwood
rich at greenwoodmap.com
Wed Jan 21 14:08:51 EST 2004
Wim Blanken (PI) wrote:
> 2. The jbox applet does not function on MS VM if you have downloaded it from
> the mapserver utilities section. It was compiled with a JDK not compatible
> with 1.1. You have to recompile it with a java compiler (for example in SDK
> 1.4 with: javac -target 1.1 jBox.class). If you use JRE instead if MS VM
> than it will work OK.
I compiled the version of jBox which is downloaded from the mapserver
utilities. I used the Sun JDK 1.3 to compile it and it works fine for me
in IE 6.0 with MS VM 5.0.0.3810. What versions of IE and MS VM are you
running into problems with ?
Richard Greenwood
www.greenwoodmap.com
