[Mapserver-users] jBox
Michael Smith
msmith at sanangelompo.org
Wed Jan 21 14:38:19 EST 2004
I am using IE 6.0, not sure which version of MS VM I have (how do I check
version?). I went to Rich's website and was able to view his maps both with
java and without java. I don't receive any error messages and everything
seems to be working fine.
Once I initialize mapserver, it seems that everything is working (my zoom
functions work, and layer control) I just see a gray box where my map should
be. It is as if my map is hidden.
****Rich wrote*****
View your page source in your browser and make sure the substitutions are
correct in: <param name="image" value="http://[host][img]"> (you should not
see the square brakets and you should have a valid, accessible path to an
image.
Should this be something to the effect of "http://192.168.110.1/[img]" I
did not change the path in my source it still shows "http://[host],[img]. I
am not sure which image I should be refering too here..help!
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Richard
Greenwood
Sent: Wednesday, January 21, 2004 1:09 PM
To: Wim Blanken (PI); mapserver-users at lists.gis.umn.edu
Subject: Re: [Mapserver-users] jBox
Wim Blanken (PI) wrote:
> 2. The jbox applet does not function on MS VM if you have downloaded
> it from the mapserver utilities section. It was compiled with a JDK
> not compatible with 1.1. You have to recompile it with a java compiler
> (for example in SDK
> 1.4 with: javac -target 1.1 jBox.class). If you use JRE instead if MS
> VM than it will work OK.
I compiled the version of jBox which is downloaded from the mapserver
utilities. I used the Sun JDK 1.3 to compile it and it works fine for me in
IE 6.0 with MS VM 5.0.0.3810. What versions of IE and MS VM are you running
into problems with ?
Richard Greenwood
www.greenwoodmap.com
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
