[Mapserver-users] jBox
Wim Blanken PI
wim.blanken at planet.nl
Wed Jan 21 15:10:35 EST 2004
Hello Richard,
I've used the compiled version in the downloaded zip file and it would not
work on
Windows XP with IE 6.0
The statusbar gave me a message: class not found.
After I recompiled the jBox using the option -target 1.1 it would work.
Sincerely
Wim Blanken
----- Original Message -----
From: "Richard Greenwood" <rich at greenwoodmap.com>
To: "Wim Blanken (PI)" <wim.blanken at planet.nl>;
<mapserver-users at lists.gis.umn.edu>
Sent: Wednesday, January 21, 2004 8:08 PM
Subject: Re: [Mapserver-users] jBox
> Wim Blanken (PI) wrote:
> > 2. The jbox applet does not function on MS VM if you have downloaded it
from
> > the mapserver utilities section. It was compiled with a JDK not
compatible
> > with 1.1. You have to recompile it with a java compiler (for example in
SDK
> > 1.4 with: javac -target 1.1 jBox.class). If you use JRE instead if MS VM
> > than it will work OK.
> I compiled the version of jBox which is downloaded from the mapserver
> utilities. I used the Sun JDK 1.3 to compile it and it works fine for me
> in IE 6.0 with MS VM 5.0.0.3810. What versions of IE and MS VM are you
> running into problems with ?
> Richard Greenwood
> www.greenwoodmap.com
