[Mapserver-users] jBox
Richard Greenwood
rich at greenwoodmap.com
Wed Jan 21 15:24:09 EST 2004
Wim Blanken (PI) wrote:
> Hello Richard,
> I've used the compiled version in the downloaded zip file and it would not
> work on
> Windows XP with IE 6.0
> The statusbar gave me a message: class not found.
> After I recompiled the jBox using the option -target 1.1 it would work.
Can you tell me which VM you are running?
1. In IE:
Tools > Internet Options > Advanced >
scroll down to "Microsoft VM" and check:
"Java console enabled"
2. If you are not running a Microsoft VM it will listed in
this section. e.g. "Sun Java VM" or similar.
3. If Java console was not already enabled, quit IE and
then restart it.
4. In IE:
View > Java Console
The version information will be the first line.
I have added your suggestion of '-target 1.1' to the build script, but I
would also like to better understand the problem you are encountering.
Thanks,
Richard Greenwood
www.greenwoodmap.com
