[Mapserver-users] simple mapserver configuration
Eric Sokolowsky
eric.sokolowsky at gsfc.nasa.gov
Wed Jan 21 16:50:20 EST 2004
On Tue, 20 Jan 2004, Norman Vine wrote:
> Pericles Nacionales writes:
> > By the way, does your app generate a
> > map with a standard MapServer CGI url, ie:
> > http://svsdev.gsfc.nasa.gov/esok/cgi-bin/map?map=/path/to/your/mapfile.map&layer=EARTH_PNG&mode=map
> AhAh I think this is it !
> Eric try
> "wms_onlineresource" "http://svsdev.gsfc.nasa.gov/esok/cgi-bin/map?"
> assuming your mapfile is "mywms.map" and is in the cgi-bin directory try
> "wms_onlineresource" "http://svsdev.gsfc.nasa.gov/esok/cgi-bin/map?map=mywms.map"
> your mapfile can be anywhere you just need the path as Pericles says
Yes, I am sure that I was getting the right map file, because a
getcapabilities request was returning an xml document with all of the
right layers. I didn't mention it in the original email (I should have
though) but my "map" is a wrapper around mapserv (so I don't need to
specify a map file in the URL):
#!/bin/sh
# Wrapper for mapserv binary.
export ROOT=/home/esok
export MS_MAPFILE=${ROOT}/mapserver/etc/wms.map
${ROOT}/public_html/cgi-bin/mapserv $*
I really do appreciate your suggestions. Do you have any more?
____ __ Eric Sokolowsky (GST) NASA Goddard Space Flight Center
/ __/__/_/__ Visualization Programmer Scientific Visualization Studio
/ __/ _/ / _/ 301.286.3751 Mailstop 935.0 Bldg 28 Rm E102
/___/_//_/__/ eric.sokolowsky at gsfc.nasa.gov Greenbelt, MD 20771
