[Mapserver-users] JBox Line
Wim Blanken PI
wim.blanken at planet.nl
Wed Jan 21 17:03:01 EST 2004
Hi Richard,
By the way, i changed the following code in the paint function
if (line) {
if ((x1==x2) && (y1==y2)) { // mouse click
To:
if (line) {
if ((x1==x2) && (y1==y2) && (x1!=0) && (y1!=0)) { // mouse click
That is because my application uses frames. A refresh caused the line tool
to always start
at x=0 and y=0. To make sure that was not the case I had to implement this
change......
Regards,
Wim Blanken
The Netherlands
----- Original Message -----
From: "Richard Greenwood" <rich at greenwoodmap.com>
To: "Wim Blanken (PI)" <wim.blanken at planet.nl>
Sent: Wednesday, January 21, 2004 10:27 PM
Subject: Re: [Mapserver-users] jBox
> Wim Blanken (PI) wrote:
> > Hello Richard,
> > I cannot reproduce the problem on XP as I am working at Home at the
Moment.
> > However i can reproduce it with Windows 98 and IE 5.00.2614.3500
> > The status bar gives me: jBox class not found
> > VM: Java 5.0 Release 5.0.0.3167
> > Btw: In the java code you state:
> > Compiler issues:
> > Sun JDK 1.2 & 1.3 work ok, but
> > 1.4 compiled classes won't run under MS VM (IE 5.5)?
> > MS J++ won't compile due to un-caught exceptions?
> > That gave me the idea about compiling with javac -target 1.1
> > As soon as I did that it ran perfectly on every system I have
encountered.
> > By the way, I have used your additions to the Jbox and included a
function
> > to be able to digitise points, lines and polygons. It works great in
> > combination with a little bit mapscript to create/update the shapefiles.
> > As soon as I'm finishing testing I'll post it to you.
> I'd be interested in seeing your additions. I just added area
> calculations to the measure tool in CVS.
> I am still pretty baffled by your VM problems. You are not running a
> significantly different MS VM than I am and I have not heard of similar
> problems from anyone else. As I said before, I have added the "-target
> 1.1" to the build file, but I suspect there is still something more to
> the story.
> Regards,
> Richard Greenwood
> www.greenwoodmap.com
