[Mapserver-users] simple mapserver configuration
Eric Sokolowsky
eric.sokolowsky at gsfc.nasa.gov
Thu Jan 22 09:13:37 EST 2004
On Wed, 21 Jan 2004, Pericles S. Nacionales wrote:
> On Wednesday 21 January 2004 03:42 pm, Eric Sokolowsky wrote:
> > On Tue, 20 Jan 2004, Pericles Nacionales wrote:
> > > Eric,
> > > I don't know if this is relevant in WMS servers or not but how about
> > > adding IMAGEURL in your WEB object?
> > Okay, done. Didn't seem to change anything though.
> > > By the way, does your app generate a
> > > map with a standard MapServer CGI url, ie:
> > > http://svsdev.gsfc.nasa.gov/esok/cgi-bin/map?map=/path/to/your/mapfile.ma
> > >p&layer=EARTH_PNG&mode=map
> > It generates the following message when I try that:
> > msDrawMap(): General error message. Image dimensions not specified.
> > msCalculateScale(): General error message. Invalid image width or height.
> > > Another question, did you check that your IMAGEPATH (IMAGEURL) is
> > > writeable by your web server's user/owner?
> > Yes, after reading the documentation a few more times, I got the mapserv
> > to write to my error log file. However, I still see a blank image in my
> > WMS client. It returns an image of the right size, but it is completely
> > black. Here's an example query:
> > http://svsdev.gsfc.nasa.gov/esok/cgi-bin/map?REQUEST=GetMap&SRS=EPSG:4326&V
> >ERSION=1.1.0&FORMAT=image/png&STYLES=default&LAYERS=EARTH_JPEG&BBOX=-110,-20
> >,-70,20&WIDTH=512&HEIGHT=512&TRANSPARENT=TRUE
> > I know that the map file is being obtained correctly because when I issue
> > getcapabilities request I get back an xml file with all of the correct
> > layers.
> > Any other suggestions anyone?
> Well, I checked your capabilities and it looks fine except that the only LAYER
> available is EARTH_PNG. Presumably you're editing things. So, the only
Yeah, Norman Vine suggested that I simplify my map file. I am including it
again below.
> other idea I have has to do with recompiling MapServer. I went back to your
> original post and looked at your "./mapserv -v" output. I noticed you had
> GDAL, TIFF, and JPEG as input. Please turn TIFF and JPEG off (use
> "--without-tiff" and "--without-jpeg" when running configure) if you're
> using GDAL. Or turn GDAL off (--without-gdal) and turn on TIFF and JPEG.
> This may or may not have anything to do with your WMS issue but having TIFF
> and JPEG input enabled along with GDAL is known to cause problems.
Yeah, I tried to make the mapserver simpler. I disabled everything that
I could, and here is now the output of mapserv -v:
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER INPUT=GDAL INPUT=SHAPEFILE
But it still only generates a blank image.
Here is my map file now:
# Start of wms.map file
MAP
NAME SVS
EXTENT -180 -90 180 90
STATUS ON
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
"wms_abstract" "Provided by the Scientific Visualization Studio."
"wms_accessconstraints" "none"
"wms_fees" "none"
"wms_onlineresource" "http://svsdev.gsfc.nasa.gov/esok/cgi-bin/map?"
"wms_title" "NASA GSFC SVS Animation Catalog"
END
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
LAYER
NAME "EARTH_PNG"
TYPE RASTER
STATUS ON
DATA "earth.png"
METADATA
"wms_title" "Earth png"
"wms_extent" "-110 -20 -70 20"
END
END
END
____ __ Eric Sokolowsky (GST) NASA Goddard Space Flight Center
/ __/__/_/__ Visualization Programmer Scientific Visualization Studio
/ __/ _/ / _/ 301.286.3751 Mailstop 935.0 Bldg 28 Rm E102
/___/_//_/__/ eric.sokolowsky at gsfc.nasa.gov Greenbelt, MD 20771
