[Mapserver-users] GDAL, TIFF, JPEG Question
Pericles S. Nacionales
nacional at cbs.umn.edu
Thu Jan 22 15:49:16 EST 2004
Dear MapServer gods,
I'm seeing a lot of folks send the output of "mapserv -v" like this:
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
INPUT=TIFF INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
At first glance it all looks good. But then look at INPUT=TIFF, INPUT=JPEG,
INPUT=GDAL. Isn't compiling GDAL, TIFF and JPEG together as input libraries
not a good idea? Or is this no longer an issue? I ask because I'm seeing a
lot of this and am wondering if we should include something like this in the
MapServer FAQ:
If you compile GDAL support make sure to disable TIFF and JPEG input support.
This can be accomplished by adding "--without-tiff --without-jpeg"
parameters when running "configure". Alternatively, you can remove
"-DUSE_TIFF" and "-DUSE_JPEG" in your Makefile (or Makefile.vc) before
running make (or nmake).
What exactly are the problems that come up when TIFF and JPEG libs are
compiled together with GDAL? I know MapServer gets confused when reading
TIFF/GeoTIFF images. Are there others?
