[Mapserver-users] GDAL, TIFF, JPEG Question
Eduardo Patto Kanegae
eduardo at consultoria.eti.br
Thu Jan 22 16:59:35 EST 2004
Hi perry,
this a very good comment....
I've just compiled one that gets:
MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF
INPUT=EPPL7 INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
and had never stop to think about that TIFF and JPEG support can be replaced by GDAL....
you mean that MapServer can be a bigger or more "fat" binany if I use GDAL with TIFF and JPEG?
thanks.
+Homepage:http://www.consultoria.eti.br ( BRASIL )
+Perfil:http://www.consultoria.eti.br/ptbr/epk.php
*Fórum ptMapServer - http://www.consultoria.eti.br/mapserverptforum/ - "Discussões relacionadas ao MapServer"
*ClickBrasil - http://www.consultoria.eti.br/clickbrasil/ - "Mapas do Brasil com dados censitários"
***Fim da Mensagem / End of Message ***
On Thu, 22 Jan 2004 14:49:16 -0600, "Pericles S. Nacionales" <nacional at cbs.umn.edu> escreveu:
> De: "Pericles S. Nacionales" <nacional at cbs.umn.edu>
> Data: Thu, 22 Jan 2004 14:49:16 -0600
> Para: mapserver-users at lists.gis.umn.edu
> Assunto: [Mapserver-users] GDAL, TIFF, JPEG Question
> Dear MapServer gods,
> I'm seeing a lot of folks send the output of "mapserv -v" like this:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=TIFF INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> At first glance it all looks good. But then look at INPUT=TIFF, INPUT=JPEG,
> INPUT=GDAL. Isn't compiling GDAL, TIFF and JPEG together as input libraries
> not a good idea? Or is this no longer an issue? I ask because I'm seeing a
> lot of this and am wondering if we should include something like this in the
> MapServer FAQ:
> If you compile GDAL support make sure to disable TIFF and JPEG input support.
> This can be accomplished by adding "--without-tiff --without-jpeg"
> parameters when running "configure". Alternatively, you can remove
> "-DUSE_TIFF" and "-DUSE_JPEG" in your Makefile (or Makefile.vc) before
> running make (or nmake).
> What exactly are the problems that come up when TIFF and JPEG libs are
> compiled together with GDAL? I know MapServer gets confused when reading
> TIFF/GeoTIFF images. Are there others?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
