[Mapserver-users] GDAL, TIFF, JPEG Question
Pericles S. Nacionales
nacional at cbs.umn.edu
Thu Jan 22 18:23:15 EST 2004
Thanks, Ed!
I guess I could be clearer but that's exactly why I brought this up.
The many and sometimes redundant options in MapServer do get people
confused. I don't know how many users configure GDAL without TIFF and
JPEG support--I would guess that most people leave them in.
-Perry N.
On Thu, 2004-01-22 at 15:31, Ed McNierney wrote:
> The chief problem is user confusion; there are many options and it can
> be easy for the user to not understand what driver is reading the data.
> It is certainly possible to build GDAL *without* support for TIFF and
> JPEG images, so the report "INPUT=TIFF, INPUT=JPEG, INPUT=GDAL" doesn't
> necessarily mean redundant drivers - but it probably does <g>!
> I believe there have been discussions about removing the "native" TIFF
> support (at least) in favor of GDAL, since there is little advantage to
> it and there are many new "TIFF" options that are really new features
> only supported by GDAL.
> MapServer doesn't get "confused" - the user does <g>. But that's
> something we should strive to avoid.
> - Ed (very minor MapServer attendant deity)
> Ed McNierney
> President and Chief Mapmaker
> TopoZone.com
> -----Original Message-----
> From: Pericles S. Nacionales [mailto:nacional at cbs.umn.edu]
> Sent: Thursday, January 22, 2004 3:49 PM
> To: mapserver-users at lists.gis.umn.edu
> Subject: [Mapserver-users] GDAL, TIFF, JPEG Question
> Dear MapServer gods,
> I'm seeing a lot of folks send the output of "mapserv -v" like this:
> MapServer version 4.0.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=PDF
> SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
> INPUT=TIFF INPUT=JPEG INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
> At first glance it all looks good. But then look at INPUT=TIFF,
> INPUT=JPEG, INPUT=GDAL. Isn't compiling GDAL, TIFF and JPEG together as
> input libraries not a good idea? Or is this no longer an issue? I ask
> because I'm seeing a lot of this and am wondering if we should include
> something like this in the MapServer FAQ:
> If you compile GDAL support make sure to disable TIFF and JPEG input
> support.
> This can be accomplished by adding "--without-tiff --without-jpeg"
> parameters when running "configure". Alternatively, you can remove
> "-DUSE_TIFF" and "-DUSE_JPEG" in your Makefile (or Makefile.vc) before
> running make (or nmake).
> What exactly are the problems that come up when TIFF and JPEG libs are
> compiled together with GDAL? I know MapServer gets confused when
> reading TIFF/GeoTIFF images. Are there others?
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Pericles S. Nacionales <nacional at cbs.umn.edu>
University of Minnesota
