[Mapserver-users] speeding up large shapefiles
Bart van den Eijnden
bartvde at xs4all.nl
Sun Jan 25 08:56:44 EST 2004
Hi Steve,
thanks for your answer. I did not want to spend a lot of time on tiling if
it would not make any sense. I once did this with ECW files without much
performance gain.
How can I get shp2tile to work on Windows? Any binaries/source code
available somewhere?
BTW what is the difference in using tile4ms and using ogrtindex?
Best regards,
Bart
On Sun, 25 Jan 2004 08:34:43 -0500, <woodbri at swoodbridge.com> wrote:
> Bart,
> This would definitely help. There is an OpenSource utility to assist
> in the tiling at http://imaptools.com/?tab=4 called shp2tile it has a
> lot of options to help tile the shpfile using different algorithms.
> If you tile the results into a directory like tiledir then you can
> run on linux:
> find tiledir -name "*.shp" -exec shptree {} \;
> find tiledir -name "*.shp" > tiledir.in
> tile4ms tiledir.in tiledir-tile
> shptree tiledir-tile
> To create spatial indexes and to create the tile index.
> As far as size of each tile, you are correct that there are a lot of
> variables involved. Because of the file system cache that most modern
> OSs have, you do not want to make the files too small as it will cost
> you more to open/close a lot of files than it will cost you to read
> some extra data into the file system cache.
> Also, if you have LOTS of attributes in your dbf file that you do not
> need for rendering then you might want to think about thinning these
> down to what you do need so you have to do less disk IO to read your
> attributes when rendering your maps.
> -Steve Woodbridge
> On 25 Jan 2004 at 13:50, Bart van den Eijnden wrote:
>> Hi list,
>> I saw a few posts from early 2003 about speeding up large shapefiles,
>> but
>> never found any conclusions on the subject.
>> I have a question with regard to speeding up large shapefiles:
>> would it make sense to split up my large (350 Mb) shapefile in tiles,
>> and
>> then use an OGR tileindex on the tiles (with quadtree indexes on both
>> tileindex and tiles)? If so, can anything be said about an ideal tile
>> size
>> in Mb, or is this too much dependent on the data?
>> Ofcourse this will also be dependent on the area I am displaying with my
>> shapefile, and the maximum area a user can get displayed (by using the
>> MINSCALE/MAXSCALE settings in my MAP file).
>> Thanks in advance for any input on this.
>> Best regards,
>> Bart
>> Mapserver-users mailing list
>> Mapserver-users at lists.gis.umn.edu
>> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
