[Mapserver-users] Compilation problems
Keith Campbell
scoota at supanet.com
Sun Jan 25 16:50:29 EST 2004
Hi All,
After getting the configure to complete successfully, I've now got
problems compiling. When 'make' is entered, a whole screed of
information is output, similar to the following...
gcc -c -O2 -Wall -DIGNORE_MISSING_DATA -DUSE_EPPL -DUSE_PROJ
-DUSE_PROJ_API_H
-DUSE_WMS_SVR -DUSE_WFS_SVR -DUSE_GD_PNG -DUSE_GD_WBMP
-DUSE_GD_FT -DUSE
_OGR -DUSE_GDAL -DUSE_POSTGIS -I/export/home/local/util/gd-2.0.15
-I/export/
home/local/util/proj/src
-I/export/home/local/util/gdal/ogr/ogrsf_frmts -I
-I/export/home/local/util/gdal/ogr/../port -I/
export/home/local/include maptemplate.c -o maptemplate.o
cc1: warning: changing search order for system directory
"/export/home/local/inc
lude"
cc1: warning: as it has already been specified as a non-system directory
... repeated many times with slight variation until a section appears
listing 'undefined symbol' and the 'first referenced in file' location.
The symbols include the likes of 'GDALSetRasterColorTable'. The process
trips up at 'GDALGetColorEntryCount' in file './libmap.a(mapdrawgdal.o)'
with the message:-
ld: fatal: Symbol referencing errors. No output written to shp2img
collect2: ld returned 1 exit status
make: *** [shp2img] Error 1
Any ideas what the cause of this is and what the solution may be? I know
the directories are non-standard, but that's not of my doing and
presumbly is allowable.
Any help is much appreciated.
Regards,
Keith
