[Mapserver-users] panning with jbox
Ryan, Adam
ARyan at co.linn.or.us
Tue Jan 27 13:42:51 EST 2004
This message is in MIME format. Since your mail reader does not understand
this format, some or all of this message may not be legible.
------_=_NextPart_001_01C3E505.5E3366D0
Content-Type: text/plain
Hi.
In the jBox.java file there is a note: "October 2003: added drag
functionality for panning", but the documentation at
http://mapserver.gis.umn.edu/doc40/jbox-howto.html
<http://mapserver.gis.umn.edu/doc40/jbox-howto.html> doesn't discuss image
panning. Can anyone demonstrate how this is done?
Can the applet parameters be manipulated on-the-fly? For example, if a pan
tool were selected, I would call document.jBox.lineon() to return the line
coordinates, but I don't want the line visible so I'd want the width=0 or
the color=transparent.
Alternatively, if box and line drawing were off, is there a way to capture
the initial mousedown location which could be compared to the current
location before the setbox_handler function was called.
Thanks for any suggestions,
Adam Ryan
GIS Analyst
Linn County GIS Department
County Courthouse / Room 25
300 SW Fourth Ave.
Albany, OR 97321
541.812.8760
aryan at co.linn.or.us
Content-Type: text/html
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C3E4C4.60C19C50">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"PersonName"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
p.MsoAutoSig, li.MsoAutoSig, div.MsoAutoSig
{margin:0in;
font-size:12.0pt;
span.EmailStyle17
{mso-style-type:personal-compose;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.term
{mso-style-name:term;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:.5in'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 face=3DArial><span =
style=3D'font-size:10.0pt;
font-family:Arial'><o:p> </o:p></span></font></p>
font-family:Arial'>Hi.<o:p></o:p></span></font></p>
font-family:Arial'>In the jBox.java file there is a note: "October =
2003:
added drag functionality for panning", but the documentation at <a
href=3D"http://mapserver.gis.umn.edu/doc40/jbox-howto.html">http://mapse=
rver.gis.umn.edu/doc40/jbox-howto.html</a>
doesn't discuss image panning.<span style=3D'mso-spacerun:yes'>
</span>Can anyone demonstrate how this is =
done?<o:p></o:p></span></font></p>
font-family:Arial'>Can the applet parameters be manipulated =
on-the-fly?<span
style=3D'mso-spacerun:yes'> </span>For example, if a pan tool =
were
selected, I would call document.jBox.lineon() to return the line =
coordinates,
but I don't want the line visible so I'd want the width=3D0 or the
color=3Dtransparent.<o:p></o:p></span></font></p>
font-family:Arial'>Alternatively, if box and line drawing were off, is =
there a
way to capture the initial mousedown location which could be compared =
to the
current location before the setbox_handler function was =
called.<o:p></o:p></span></font></p>
font-family:Arial'>Thanks for any =
suggestions,<o:p></o:p></span></font></p>
font-family:Arial;mso-no-proof:yes'>Adam =
Ryan<o:p></o:p></span></font></p>
<p class=3DMsoNormal><st1:PersonName><font size=3D2 face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;mso-no-proof:yes'>GIS</span>=
</font></st1:PersonName><font
yes'> Analyst<o:p></o:p></span></font></p>
font-family:Arial;mso-no-proof:yes'>Linn County =
</span></font><st1:PersonName><font
yes'>GIS</span></font></st1:PersonName><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial;mso-no-proof:yes'> =
Department<o:p></o:p></span></font></p>
font-family:Arial;mso-no-proof:yes'>County Courthouse / Room =
25<o:p></o:p></span></font></p>
font-family:Arial;mso-no-proof:yes'>300 SW Fourth =
Ave.<o:p></o:p></span></font></p>
font-family:Arial;mso-no-proof:yes'>Albany, OR =
97321<o:p></o:p></span></font></p>
<p class=3DMsoAutoSig><font size=3D2 face=3DArial><span =
font-family:Arial;mso-no-proof:yes'>541.812.8760</span></font><span
style=3D'mso-no-proof:yes'><o:p></o:p></span></p>
font-family:Arial;mso-no-proof:yes'>aryan at co.linn.or.us</span></font><sp=
an
<p class=3DMsoNormal><font size=3D3 face=3D"Times New Roman"><span =
style=3D'font-size:
12.0pt'><o:p> </o:p></span></font></p>
</div>
</body>
</html>
------_=_NextPart_001_01C3E505.5E3366D0--
