[Mapserver-users] Projection Systems question
Amit S BEHERE
abehere at cs.ucsd.edu
Wed Jan 28 22:42:26 EST 2004
Hi all,
I am having the following problem. I have a shapefile with the data in
projection system 1983_UTM_Zone_11N. I am trying to set up a layer in
mapserver using this shape file. I took the example1.map file in the
tutorial and made changes to it. The salient ones being
changing the extent to the correct coordinates (found via ArcView)
changing the projection to init epsg: 26911 (for UTM Zone 11 N) and
changing the name and data setting for layer.
I also changed the type to point and set minsize to be 20.
I am also appending the mapfile. Can some
one tell me what I am doing wrong ? Thanks in advance
MAP
IMAGETYPE PNG
EXTENT 385538 3761010 391329 3764477
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
#"lon_0=-100"
# Alternatively, you can specify an EPSG code.
"init=epsg:26911"
END
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME vernon_trees
DATA vernon_trees
STATUS DEFAULT
TYPE POINT
PROJECTION
"init=epsg:26911"
END
CLASS
COLOR 232 232 232
MINSIZE 20
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just changes
the rules"......Vishwanathan Anand
