[Mapserver-users] OGR unable to access datasource
Paul Spencer
spencer at dmsolutions.ca
Thu Jan 29 19:37:15 EST 2004
try downloading
http://www2.dmsolutions.ca/netbin/mapserv.zip
I'll leave it there for a couple of days. Please note that I am not
supporting this build.
Cheers,
Paul
Van Ulden, Joost wrote:
> Actually we have not ruled out whether my version of mapserver supports VRT
> or not. How would I check? Is there a binary somewhere that supports it
> for sure? I can test that one.
> Joost van Ulden
> Programmer/Analyst
> Natural Resources Canada / Ressources naturelles Canada
> Geological Survey of Canada / Commission geologique du Canada
> 101 - 605 Robson Street / 101 - 605 rue Robson
> Vancouver, B.C. / Vancouver (C.-B.)
> V6B 5J3
> Office/Bureau: 604.666.7525
> fax/telecopieur: 604.666.1124
> jvanulde at nrcan.gc.ca
>>-----Original Message-----
>>From: Paul Spencer [mailto:pagameba at magma.ca]
>>Sent: Thursday, January 29, 2004 1:49 PM
>>To: Van Ulden, Joost
>>Cc: Mapserver-Users at Lists. Gis. Umn. Edu
>>(mapserver-users at lists.gis.umn.edu)
>>Subject: Re: [Mapserver-users] OGR unable to access datasource
>>I wonder if this could be an IIS issue? IIS runs as a different user
>>normally, and has considerably reduced privileges in order to
>>block up
>>potential security issues. Can you possibly set up Apache
>>and try with
>>Apache? If it works with Apache then we can be sure it is an IIS
>>configuration issue and focus on figuring out why it won't work.
>>The other possibility is that your mapserver does not support
>>VRT, did
>>we rule that out yet?
>>Paul
>>>Hi Tyler,
>>>Here is the output from ogrinfo. Looks like its working, however I
>>>still unable to get mapserver to connect. I have tried putting the
>>><OGRVRTDataSource> directly in the mapfile CONNECTION and still get
>>>the same
>>>error:
>>>msDrawMap(): Image handling error. Failed to draw layer named
>>>'OGRPoints'.
>>>msOGRFileOpen(): OGR error. Open failed for OGR connection `
>>>ODBC:foo/foo at mydsn,Desc_story Desc_story wkbPoint WGS84 '.
>>File not found or
>>>unsupported format.
>>>Looking forward to your response.
>>>C:\OpenEV_FW\bin>ogrinfo
>>>C:\inetpub\wwwroot\MS_DEMO\mapserver\data\ogr.ovf
>>>ERROR 4: Update access not supported for VRT datasources.
>>>Had to open data source read-only.
>>>INFO: Open of `C:\inetpub\wwwroot\MS_DEMO\mapserver\data\ogr.ovf'
>>>using driver `VRT' successful.
>>>1: story (Point)
>>>story ERROR 4: Update access not supported for VRT
>>datasources. Had to open
>>>OGRFeature(story):87
>>> desc_id (String) = 400E2174-65BF-3224-7CEF493349368AE7
>>> group_id (String) = 0
>>> comm_id (String) = DE9E2A07-B0D0-EA24-1BD6282422D24117
>>> user_id (String) = 4A335096-7ADD-419B-9E16-1995F233D3F8
>>> elev (Real) = 0
>>> units (String) =
>>> rtype (String) =
>>> mu (String) =
>>> ldesc (String) =
>>> min (String) =
>>> lmu (String) =
>>> struct (String) =
>>> txt (String) =
>>> snum (String) =
>>> purp (String) =
>>> sfeat (String) =
>>> azi (Real) = 0
>>> dip (Real) = 0
>>> stdesc (String) =
>>> name (String) =
>>> sdesc (String) =
>>> story_x (Real) = -1993136.4272429
>>> story_y (Real) = 471899.80462409
>>> share (Integer) = 0
>>> release (Integer) = 1
>>> date (String) = 2004-01-22 16:08:11.000
>>> POINT (-1993136.427 471899.805 0.000)
>>>Joost van Ulden
>>>Programmer/Analyst
>>>Natural Resources Canada / Ressources naturelles Canada Geological
>>>Survey of Canada / Commission geologique du Canada 101 - 605 Robson
>>>Street / 101 - 605 rue Robson Vancouver, B.C. / Vancouver (C.-B.)
>>>V6B 5J3
>>>>From: Tyler Mitchell [mailto:TMitchell at lignum.com]
>>>>Sent: Thursday, January 29, 2004 9:46 AM
>>>>> LAYER
>>>>> NAME OGRPoints
>>>>> TYPE POINT
>>>>> CONNECTIONTYPE OGR
>>>>> CONNECTION "c:\inetpub\wwwroot\MS_DEMO\ogr.ovf"
>>>>> DATA "Desc_story"
>>>>> STATUS default
>>>>> CLASS
>>>>> COLOR 255 0 0
>>>>> END
>>>>I just asked for your layer definition, I see it here in your
>>>>old email, so nevermind. Are you sure about the text case for
>>>>the "DATA" parameter? Send me your output from ogrinfo!
>>>_______________________________________________
>>>Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
>>>http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
>>|Paul Spencer spencer at dmsolutions.ca |
>>|Applications & Software Development |
>>|DM Solutions Group Inc http://www.dmsolutions.ca/|
