[Mapserver-users] OGR unable to access datasource
Van Ulden, Joost
jvanulde at nrcan.gc.ca
Thu Jan 29 19:21:12 EST 2004
Actually we have not ruled out whether my version of mapserver supports VRT
or not. How would I check? Is there a binary somewhere that supports it
for sure? I can test that one.
Joost van Ulden
Programmer/Analyst
Natural Resources Canada / Ressources naturelles Canada
Geological Survey of Canada / Commission geologique du Canada
101 - 605 Robson Street / 101 - 605 rue Robson
Vancouver, B.C. / Vancouver (C.-B.)
V6B 5J3
Office/Bureau: 604.666.7525
fax/telecopieur: 604.666.1124
> -----Original Message-----
> From: Paul Spencer [mailto:pagameba at magma.ca]
> Sent: Thursday, January 29, 2004 1:49 PM
> To: Van Ulden, Joost
> Cc: Mapserver-Users at Lists. Gis. Umn. Edu
> (mapserver-users at lists.gis.umn.edu)
> Subject: Re: [Mapserver-users] OGR unable to access datasource
> I wonder if this could be an IIS issue? IIS runs as a different user
> normally, and has considerably reduced privileges in order to
> block up
> potential security issues. Can you possibly set up Apache
> and try with
> Apache? If it works with Apache then we can be sure it is an IIS
> configuration issue and focus on figuring out why it won't work.
> The other possibility is that your mapserver does not support
> VRT, did
> we rule that out yet?
> Paul
> Van Ulden, Joost wrote:
> > Hi Tyler,
> > Here is the output from ogrinfo. Looks like its working, however I
> > still unable to get mapserver to connect. I have tried putting the
> > <OGRVRTDataSource> directly in the mapfile CONNECTION and still get
> > the same
> > error:
> > msDrawMap(): Image handling error. Failed to draw layer named
> > 'OGRPoints'.
> > msOGRFileOpen(): OGR error. Open failed for OGR connection `
> > ODBC:foo/foo at mydsn,Desc_story Desc_story wkbPoint WGS84 '.
> File not found or
> > unsupported format.
> > Looking forward to your response.
> > C:\OpenEV_FW\bin>ogrinfo
> > C:\inetpub\wwwroot\MS_DEMO\mapserver\data\ogr.ovf
> > ERROR 4: Update access not supported for VRT datasources.
> > Had to open data source read-only.
> > INFO: Open of `C:\inetpub\wwwroot\MS_DEMO\mapserver\data\ogr.ovf'
> > using driver `VRT' successful.
> > 1: story (Point)
> > story ERROR 4: Update access not supported for VRT
> datasources. Had to open
> > OGRFeature(story):87
> > desc_id (String) = 400E2174-65BF-3224-7CEF493349368AE7
> > group_id (String) = 0
> > comm_id (String) = DE9E2A07-B0D0-EA24-1BD6282422D24117
> > user_id (String) = 4A335096-7ADD-419B-9E16-1995F233D3F8
> > elev (Real) = 0
> > units (String) =
> > rtype (String) =
> > mu (String) =
> > ldesc (String) =
> > min (String) =
> > lmu (String) =
> > struct (String) =
> > txt (String) =
> > snum (String) =
> > purp (String) =
> > sfeat (String) =
> > azi (Real) = 0
> > dip (Real) = 0
> > stdesc (String) =
> > name (String) =
> > sdesc (String) =
> > story_x (Real) = -1993136.4272429
> > story_y (Real) = 471899.80462409
> > share (Integer) = 0
> > release (Integer) = 1
> > date (String) = 2004-01-22 16:08:11.000
> > POINT (-1993136.427 471899.805 0.000)
> > Joost van Ulden
> > Programmer/Analyst
> > Natural Resources Canada / Ressources naturelles Canada Geological
> > Survey of Canada / Commission geologique du Canada 101 - 605 Robson
> > Street / 101 - 605 rue Robson Vancouver, B.C. / Vancouver (C.-B.)
> > V6B 5J3
> >>From: Tyler Mitchell [mailto:TMitchell at lignum.com]
> >>Sent: Thursday, January 29, 2004 9:46 AM
> >>> LAYER
> >>> NAME OGRPoints
> >>> TYPE POINT
> >>> CONNECTIONTYPE OGR
> >>> CONNECTION "c:\inetpub\wwwroot\MS_DEMO\ogr.ovf"
> >>> DATA "Desc_story"
> >>> STATUS default
> >>> CLASS
> >>> COLOR 255 0 0
> >>> END
> >>I just asked for your layer definition, I see it here in your
> >>old email, so nevermind. Are you sure about the text case for
> >>the "DATA" parameter? Send me your output from ogrinfo!
> > Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> > http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
> |Paul Spencer spencer at dmsolutions.ca |
> |Applications & Software Development |
> |DM Solutions Group Inc http://www.dmsolutions.ca/|
