[Mapserver-users] Projection Systems question
Ed McNierney
ed at topozone.com
Wed Jan 28 23:10:26 EST 2004
Amit -
You didn't say what the problem is. What is happening (or not
happening) when you try to generate a map from this mapfile? What is
the URL you're using (i.e. what CGI parameters are you specifying)?
- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com
-----Original Message-----
From: Amit S BEHERE [mailto:abehere at cs.ucsd.edu]
Sent: Wednesday, January 28, 2004 10:42 PM
To: mapserver-users at lists.gis.umn.edu
Cc: amitbehere at rediffmail.com
Subject: [Mapserver-users] Projection Systems question
Hi all,
I am having the following problem. I have a shapefile with the data in
projection system 1983_UTM_Zone_11N. I am trying to set up a layer in
mapserver using this shape file. I took the example1.map file in the
tutorial and made changes to it. The salient ones being
changing the extent to the correct coordinates (found via ArcView)
changing the projection to init epsg: 26911 (for UTM Zone 11 N) and
changing the name and data setting for layer.
I also changed the type to point and set minsize to be 20.
I am also appending the mapfile. Can some one tell me what I am doing
wrong ? Thanks in advance
MAP
IMAGETYPE PNG
EXTENT 385538 3761010 391329 3764477
SIZE 400 300
SHAPEPATH "data"
IMAGECOLOR 255 255 255
PROJECTION
# "proj=laea"
# "ellps=clrk66"
# "lat_0=45"
#"lon_0=-100"
# Alternatively, you can specify an EPSG code.
"init=epsg:26911"
END
# Start of LAYER DEFINITIONS
LAYER # States polygon layer begins here
NAME vernon_trees
DATA vernon_trees
STATUS DEFAULT
TYPE POINT
PROJECTION
"init=epsg:26911"
END
CLASS
COLOR 232 232 232
MINSIZE 20
END
END # States polygon layer ends here
# End of LAYER DEFINITIONS -------------------------------
END # end of map file/object
Amit Behere.
UCSD.
"Technology doesn't make your life more difficult or easy, it just
changes the rules"......Vishwanathan Anand
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
