[Mapserver-users] Searching for crossing streets
Mario Servin
mservin at tecnoaccion.com.ar
Tue Mar 2 10:22:19 EST 2004
I did the following CGI query for getting the closest street near the
click of the mouse:
http://mariolaptop/MYPages/Scripts/mapserv_41.exe?mode=nquery&itemquery=[NAME]&layer=calles&imgxy=10+10&mapext=shape&imgext=-71.899651+-41.582889+-71.086875+-40.770450&map=c%3A%2FDocuments+and+Settings%2Fmario%2FMyPages%2Fitasca%2Fquery.map&savequery=true&img.x=452&img.y=265&map_calles_tolerance=10
I use a query.map and a query .html that follows:
query.html:
Calle: [ID] Nombre:[NAME]<br>
query.map:
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT -71.89965056 -41.36073059 -71.08687515 -40.99260904
UNITS DD
SHAPEPATH "Bariloche"
IMAGECOLOR 255 255 255
# you may need to change this to match your MapServer build
IMAGETYPE PNG
# Start of layer definitions
#Bariloche
LAYER
NAME calles
GROUP Calles
TYPE LINE
DATA Calles
STATUS OFF
TOLERANCE 1
TOLERANCEUNITS meters
CLASS
TEMPLATE query.html
END
END
END # Map File
As you can see I modify the TOLERANCE attribute of my layer 'calles'
(streets in spanish) to get the minimum number of streets near my location.
I want to use this for finding two crossing streets near me. The process
will follow like this: wiht a minimum TOLERANCE value (10 meters as an
example ) I found a street. Then I should increment the TOLERANCE and
requery to mapserver. Here's my problem. I need to use the previous result
to filter the new ones as again I will get the same street (among others).
This time I need the nearest street EXCEPT the found in the previous query.
I did set the SAVEQUERY=true but I do not know how to use it. Can anybody
help me?.
Regards
Mario
