[Mapserver-users] Re: help me !!!
Dylan Keon
keon at nacse.org
Tue Mar 2 14:00:58 EST 2004
Dharani,
I haven't played around with tiger line data. You probably just need to
set LABELITEM for each layer, then define a LABEL object within each
CLASS. Here are a couple of posts from the archives that might help:
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0202/msg00113.html
http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0301/msg00553.html
You might also find some clues on the OGR howto page:
http://mapserver.gis.umn.edu/doc/ogr-howto.html
--Dylan
Dharani Babu wrote:
> Mr.Keon
> I am dharani babu from chennai , india . I found your reference at
> http://mapserver.gis.umn.edu/data2/wilma/mapserver-users/0308/msg00012.html
> .( I am sending this mail after posting several time to map server list )
> I am a new map server user . I request you to consider help me with
> my problem .I have been as of now able to render TIGER file maps thro
> Mapserver . I have the ms4w package set up and have apache running . I
> am now able to render theTIGER files' CompleteChain , Landmarks and PIP
> . But I am trying to find hard to display the names ( labels right)on
> the streets and landmarks and capitals .To tell you what I did .....I
> ran ogrinfo on the tiger folder and got the following Layers .
> Had to open data source read-only.
> INFO: Open of `c:/ms4w/apache/htdocs/demof/data/rm'
> using driver `TIGER' successful.
> 1: CompleteChain (Line String)
> 2: AltName (None)
> 3: FeatureIds (None)
> 4: ZipCodes (None)
> 5: Landmarks (Point)
> 6: AreaLandmarks (None)
> 7: KeyFeatures (None)
> 8: Polygon (None)
> 9: EntityNames (Point)
> 10: IDHistory (None)
> 11: PolyChainLink (None)
> 12: PIP (Point)
> 13: TLIDRange (None)
> 14: ZipPlus4 (None)
> And I am pasting the mapfile content I use. Please go thro it and advise
> me WHERE and HOW Should I add
> the LABELs ? So that I can get the names of capitals and landmarks and
> streets displayed on the
> map . I tried to add the LABEL defintions(which I found in your message)
> to the LAYERS but got mapserver error .
> # Start of map file
> NAME DEMO
> STATUS ON
> SIZE 600 600
> EXTENT -71.451310 42.737590 -70.575094 43.274201
> #UNITS DEGREES
> SHAPEPATH "C:/ms4w/apache/htdocs/demof/data/rm/"
> IMAGECOLOR 255 255 255
> IMAGETYPE png
> # Projection definition, consult the PROJ.4 documentation for parameter
> discussi
> #PROJECTION
> # "proj=utm"
> # "ellps=GRS80"
> # "zone=10"
> # "north"
> # "no_defs"
> # "init=EPSG:26910"
> #END
> # Start of web interface definition
> WEB
> HEADER tiger
> TEMPLATE temp_rm4.html
> FOOTER demo_footer.html
> # MINSCALE 1000
> # MAXSCALE 1550000
> IMAGEPATH "C:/ms4w/apache/htdocs/temp_rm1/"
> IMAGEURL "/temp_rm1/"
> # LOG "demo.log"
> END
> QUERYMAP
> SIZE 200 200
> STATUS ON
> STYLE HILITE
> COLOR 255 0 0
> END
> # Start of reference map
> REFERENCE
> IMAGE graphics/dem.gif
> EXTENT 481314.93 5620068.63 703440.19 5837331.76
> SIZE 200 192
> STATUS OFF
> COLOR -1 -1 -1
> OUTLINECOLOR 255 0 0
> END
> # Start of legend
> LEGEND
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> STATUS ON
> END
> # Setting up output formats
> #OUTPUTFORMAT
> # NAME png
> #DRIVER "GD/PNG"
> #MIMETYPE "image/png"
> #IMAGEMODE RGB #PC256
> #EXTENSION "png"
> #END
> # Start of scalebar
> SCALEBAR
> LABEL
> COLOR 255 255 255
> SIZE tiny
> END
> STYLE 1
> SIZE 50 2
> COLOR 255 255 255
> UNITS KILOMETERS
> INTERVALS 1
> TRANSPARENT TRUE
> STATUS TRUE
> END
> SYMBOL
> NAME "circle"
> TYPE ellipse
> FILLED true
> POINTS
> 1 1
> END
> END
> # Start of layer definitions
> LAYER
> GROUP tigerdata
> NAME tiger1
> TYPE LINE
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "C:/ms4w/apache/htdocs/demof/data/rm"
> DATA "CompleteChain"
> CLASS
> SYMBOL "circle"
> SIZE 1
> COLOR 200 0 0
> END
> END
> LAYER
> GROUP tigerdata
> NAME tiger5
> TYPE POLYGON
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "C:/ms4w/apache/htdocs/demof/data/tigertest"
> DATA "Landmarks"
> CLASS
> SYMBOL "circle"
> SIZE 1
> COLOR 200 0 0
> END
> END
> LAYER
> GROUP tigerdata
> NAME tiger12
> TYPE POINT
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> DATA "PIP"
> CLASS
> SYMBOL "circle"
> SIZE 8
> COLOR 0 0 200
> END
> END
> END # Map file
> Please advise me with the above stuff !!! As you can see I have been
> able to render the LAYERS which have geometry ( line and point ) but I
> dont know what I can do with layers that have no geomoetry . ...
> Expecting your reply
> With regards and thanks in advance
> dharani
