RES: [Mapserver-users] Compiling mapserver 4 with gdal + ogr + wfs suport
Sandro Danilo Gatti
Gatti at cpqd.com.br
Fri Mar 12 10:54:46 EST 2004
Daniel
thanks a lot for your help. It worked beautifully. I was using GDAL 1.2.0 and mapserver 4.0.1.
Frank, I haven't tried your solution, as Daniel's solution came first and solved my problem :-) , but thanks for your help too.
Best regards
Sandro.
Sandro Danilo Gatti
Analista de Sistemas
CPqD Telecom & IT Solutions
Tel.: +55 19 3705-4420
gatti at cpqd.com.br
http://www.cpqd.com.br
|- -----Mensagem original-----
|- De: Daniel Morissette [mailto:dmorissette at dmsolutions.ca]
|- Enviada em: sexta-feira, 12 de março de 2004 12:05
|- Para: Sandro Danilo Gatti
|- Cc: mapserver-users at lists.gis.umn.edu
|- Assunto: Re: RES: [Mapserver-users] Compiling mapserver 4 with gdal +
|- ogr + wfs suport
|- Sandro Danilo Gatti wrote:
|- > now I get the following :
|- > $ ./configure --with-proj --with-gdal
|- --with-ogr=/usr/local/bin/gdal-config --with-wmsclient
|- --with-wfsclient --with-wsm --with-wfs
|- > checking whether we should include OGR support...
|- > checking for OGRRegisterAll in -lgdal.1.1... (cached) no
|- > configure: warning: OGR not found in system
|- libs... use --with-ogr=DIR.
|- You must be using GDAL 1.1.9 or 1.2.0? The name of the GDAL
|- library has
|- changed in those versions and we had to change a test in the
|- configure
|- script. However this was done only after the 4.0.1 release
|- so the fix
|- hasn't been released yet.
|- You can get a new configure for MS 4.0.1 from
|- http://www2.dmsolutions.ca/tmp/ms-401-configure.tar.gz
|- Just extract the file and copy it over your configure
|- script, then rerun
|- configure and you should be fine.
|- Daniel
|- Daniel Morissette dmorissette at dmsolutions.ca
|- DM Solutions Group http://www.dmsolutions.ca/
