[Mapserver-users] arcgrid to ascii(etc)
Jason M. Nielsen
jnielsen at aero-graphics.com
Mon May 3 12:26:49 EDT 2004
Quoting Frank Warmerdam <warmerdam at pobox.com>:
> Jason,
> I hope the above isn't the complete error message. It should have reported
> something about AAIGrid does not support Create() method. For gdalwarp you
> will have to output to a format that supports random writing of raster data
> (aka has a Create() method - such as GeoTIFF). Then translate to Arc/Info
> ASCII Grid with gdal_translate.
Part of my cut and past didnt make it into the email.
Output driver `AAIGrid' not recognised or does not support
direct output file creation. The following format drivers are configured
and support direct output:
VRT: Virtual Raster
GTiff: GeoTIFF
NITF: National Imagery Transmission Format
HFA: Erdas Imagine Images (.img)
ELAS: ELAS
MEM: In Memory Raster
BMP: MS Windows Device Independent Bitmap
PNM: Portable Pixmap Format (netpbm)
ENVI: ENVI .hdr Labelled
PAux: PCI .aux Labelled
MFF: Atlantis MFF Raster
MFF2: Atlantis MFF2 (HKV) Raster
Anyhow, I was unaware of not being able to go directly through gdalwarp. I tried
the gdal_translate and it seems to have had no problem.
Thanks!
