[Mapserver-users] Drawing ADF Files with Mapserver
Daniel Morissette
dmorissette at dmsolutions.ca
Mon May 3 21:12:01 EDT 2004
Richard Gould wrote:
> And here is MapServer hating me:
> *Warning*: [MapServer Error]: msOGRFileOpen(): Open failed for OGR
> connection `corp/tbec'. File not found or unsupported format. in
> */home/www/htdocs/viewer/out/map.php* on line *161*
Perhaps try using an absolute path to the coverage directory in the
CONNECTION string and see if that helps.
Also, which version of GDAL/OGR are you using? I think coverage support
was added only around 1.1.9 (or was it 1.1.8?). You may want to try
opening the coverage using ogrinfo and see if OGR can read itat all.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
