[Mapserver-users] MapServer/gdal doesn't like Photoshop tiff
Delfos, Jacob
jacob.delfos at maunsell.com
Wed May 19 00:27:16 EDT 2004
I have also been unable to load a photoshop 7.0 TIFF file. Have not had
problems with any other TIFF. Mine was 24bit RGB. A possible solution would
be to save it from ER Viewer.
-----Original Message-----
From: Marvin Humphrey [mailto:marvin at rectangular.com]
Sent: Wednesday, 19 May 2004 12:01 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] MapServer/gdal doesn't like Photoshop tiff
Greetings,
Problem: I load the mapserver tutorial at
http://terrasip.gis.umn.edu/projects/tutorial/ . I take the tiff
source used for example1-5.map, scp it off from the FreeBSD 4.9 box
running MapServer to a Mac OS X 10.3 box running Photoshop 7.0 and
resave it without editing. After scp'ing it back, MapServer doesn't
process it anymore -- vector data displays when I load example1-5, but
raster data is missing, and the display happens fast enough to suggest
that MapServer is simply rejecting the file rather than misinterpreting
its contents on a pixel-by-pixel basis.
(My eventual goal is to take other raster sources (specifically GLOBE
datafiles), turn them into tiffs and process them. This
save-with-no-changes operation is for troubleshooting.)
I've been through debugging the conflict between the internal tiff
support and gdal. (How about making --with-tiff and --with-gdal an
illegal compile combination?). MapServer has been recompiled
--without-tiff. Here's my config:
# ./mapserv40 -v
MapServer version 4.0.2 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
gdal (version 1.2.0) has tiff support, since gtiff is in this list:
# gdal-config --formats
gxf gtiff hfa aigrid aaigrid ceos ceos2 iso8211 xpm sdts raw dted mem
jdem envisat elas fit vrt usgsdem l1b nitf bmp pcidsk bsb gif jpeg png
tiffinfo has this to say about the original image from the tutorial...
# tiffinfo mod09a12003161_ugl_ll_8bit.tif
mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 33550
(0x830e) ignored.
mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 33922
(0x8482) ignored.
mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 34735
(0x87af) ignored.
mod09a12003161_ugl_ll_8bit.tif: Warning, unknown field with tag 34737
(0x87b1) ignored.
TIFF Directory at offset 0x1152f68
Image Width: 3480 Image Length: 1740
Resolution: 1, 1 (unitless)
Bits/Sample: 8
Sample Format: unsigned integer
Compression Scheme: None
Photometric Interpretation: RGB color
Software: "ERDAS IMAGINE"
Samples/Pixel: 3
Rows/Strip: 8
Planar Configuration: single image plane
... and this to say about the copy...
# tiffinfo mod09a12003161_ugl_ll_8bit_mild.tif
mod09a12003161_ugl_ll_8bit_mild.tif: Warning, unknown field with tag
700 (0x2bc) ignored.
34665 (0x8769) ignored.
TIFF Directory at offset 0x8
Subfile Type: (0 = 0x0)
Resolution: 72, 72 pixels/inch
Bits/Sample: 8
Date & Time: "2004:05:18 19:26:44"
Software: "Adobe Photoshop 7.0"
Samples/Pixel: 3
Rows/Strip: 1740
Photoshop Data: <present>, 9182 bytes
What is it about the Photoshop tiff that MapServer or gdal doesn't
like? It is an 8-bit-per-channel image, just like the original. All
image-previews are disabled and ICC profile is not embedded (not that
any of that should matter). Contrary to some reports I have unearthed
while googling the mail archives, MapServer does not require an
indexed-color 8-bit-per-pixel tiff -- because this original is a
straight-up 24-bit RGB (3-channel x 8-bits-per-channel = 24-bits-per
pixel) image! (I imagine that MapServer must choke on
16-bit-per-channel images, like the 16-bit greyscale of GLOBE files, or
the 48-bit RGB files used in high-end scanning and image-manipulation.)
The problem can't possibly be something as straightforward as
byte-order, can it?
-- Marvin Humphrey
Mapserver-users mailing list
Mapserver-users at lists.gis.umn.edu
http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
