[Mapserver-users] National Atlas Datasets
Scott Ainslie
dmi at webmail.co.za
Thu May 20 11:04:38 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_005B_01C43E8C.88CD3570
Content-Type: text/plain;
charset="iso-8859-1"
Content-Transfer-Encoding: 7bit
> > What projections do these datasets use.
> > <snip>
> > Could someone please give me an example of the projection section of
> the map
> > file that would work with this kind of data.
> Scott,
> When you download data from the National Atlas, there is a link to a
> description of the dataset:
> http://nationalatlas.gov/atlasftp.html#layerstable
> Under (Column 2)
> This provides the metadata for each file, which describes, among other
> things, the spatial reference information for the data set. I think that
> all of the data on the NA site is in Decimal Degrees, and uses NAD83.
> That said, since it seems like you are a new MapServer user, I would
> encourage you to start with as few variables as possible. You don't HAVE
> to supply projection information in the Mapfile. Start with a simple
> mapfile that only has one layer. In the Identification_Information
> section of the metadata is a section that describes the spatial domain's
> bounding coordinates. Use these to specify your mapextent.
> You'll most likely face enough issues initially figuring out how to
> configure everything. Once you get it working with a simple mapfile, you
> can add in projection information and start working with data sets that
> use different projections, OGR, etc.
> My $0.02.
> Chip
Quite proud of what I have, looked at this software for the first time
yesterday! The scale bars simply produce nothing until you are zoomed right
in and then they say 10km in reality is about 1500km on the scale.
If I could sort my projections out and map data from a database I will be
flying ;-)
Thanks
Scott
Content-Type: image/jpeg;
name="Mapserver1.jpg"
Content-Transfer-Encoding: base64
Content-Disposition: attachment;
filename="Mapserver1.jpg"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=
------=_NextPart_000_005B_01C43E8C.88CD3570--
