[Mapserver-users] vim syntax file
Tyler Mitchell
TMitchell at lignum.com
Wed May 26 11:45:01 EDT 2004
Andreas,
Beautiful, thanks for sharing. Works with vim for windows fine.
Tyler
mapserver-users-admin at lists.gis.umn.edu wrote on 05/26/2004 02:36:12 AM:
> Hello List,
> I have written a syntax file for vi/vim. It was my first go at vim
syntax
> files and only represents a first draft. I am sure there is still plenty
of
> room for improvements. The keywords are based on the TextPad Symbol
> Map_40.syn file contributed by Christopher Thorne, which can be found on
the
> Mapserver utility page.
> To register this file in vim copy map.vim (also listed at the bottom of
the
> mail) to the vim syntax directory (on Suse:
/usr/share/vim/current/syntax)
> and add two lines to filetype.vim (on Suse Linux:
/usr/share/vim/current)
> according to the example shown below:
> " Manpage
> au BufNewFile,BufRead *.man setf man
> ############ADD#############
> " Map
> au BufNewFile,BufRead *.map setf map
> " Maple V
> au BufNewFile,BufRead *.mv,*.mpl,*.mws setf maple
> I hope the file is somehow usefull to anybody out there. If there are
any
> questions or suggestions, please feel free to contact me.
> Cheer
> Andreas
> Dr. Andreas Hirner
> German Remote Sensing Data Center (DFD)
> German Aerospace Center (DLR)
> P.O.Box 11 16 Tel: +49-8153-28-3389
> D-82234 Wessling Fax: +49-8153-28-1445
> Germany
> E-mail: andreas.hirner at dlr.de
> map.vim
> " Vim syntax file
> " Language: map (umn mapserver config file)
> " Maintainer: Andreas Hirner <andreas.hirner at dlr.de>
> " Last Change: $Date: 2004/05/25 19:19:37 $
> " Filenames: *.map
> " URL: ftp://xxx@xxx.xx/map.vim
> " Note: The definitions below are taken from TextPad syntax
> definitions
> (*.syn) by Chris Thorne (thorne at dmsolutions.ca) as of May 2004, for
version
> 4.0 Mapserver
> " For version 5.x: Clear all syntax items
> " For version 6.x: Quit when a syntax file was already loaded
> if version < 600
> syntax clear
> elseif exists("b:current_syntax")
> finish
> endif
> " Always ignore case
> syn case ignore
> " General keywords first order
> syn keyword mapDefine CLASS END JOIN LABEL LAYER LEGEND MAP
METADATA
> OUTPUTFORMAT
> syn keyword mapDefine PROJECTION QUERYMAP REFERENCE SCALEBAR
> STYLE SYMBOL
> WEB
> " General keywords second order
> syn keyword mapIdentifier ALPHACOLOR ANGLE ANTIALIAS
> syn keyword mapIdentifier BACKGROUNDCOLOR BACKGROUNDSHADOWCOLOR
> BACKGROUNDSHADOWSIZE BUFFER
> syn keyword mapIdentifier CHARACTER CLASSITEM COLOR CONNECTION
> CONNECTIONTYPE
> syn keyword mapIdentifier DATA DATAPATTERN DEBUG DRIVER DUMP
> syn keyword mapIdentifier EMPTY ERROR EXPRESSION EXTENSION EXTENT
> syn keyword mapIdentifier FEATURE FILLED FILTER FILTERITEM FONT
FONTSET
> FOOTER FORCE FORMATOPTION FROM
> syn keyword mapIdentifier GAP GRATICULE GRID GROUP HEADER
> syn keyword mapIdentifier IMAGE IMAGECOLOR IMAGEMODE IMAGEPATH
IMAGEQUALITY
> IMAGETYPE IMAGEURL INDEX INTERLACE INTERVALS
> syn keyword mapIdentifier KEYIMAGE KEYSIZE KEYSPACING
> syn keyword mapIdentifier LABELANGLEITEM LABELCACHE LABELFORMAT
LABELITEM
> LABELMAXSCALE LABELMINSCALE LABELREQUIRES LABELSIZEITEM LATLON LINECAP
> LINEJOIN LINEJOINMAXSIZE LOG
> syn keyword mapIdentifier MARKER MARKERSIZE MAXARCS MAXBOXSIZE
MAXFEATURES
> MAXINTERVAL MAXSCALE MAXSIZE MAXSUBDIVIDE MAXTEMPLATE MIMETYPE
> syn keyword mapIdentifier MINARCS MINBOXSIZE MINDISTANCE
MINFEATURESIZE
> MININTERVAL MINSCALE MINSIZE MINSUBDIVIDE MINTEMPLATE
> syn keyword mapIdentifier NAME
> syn keyword mapIdentifier OFFSET OFFSITE OUTLINECOLOR
> OVERLAYBACKGROUNDCOLOR
> OVERLAYCOLOR OVERLAYMAXSIZE OVERLAYMINSIZE OVERLAYOUTLINECOLOR
OVERLAYSIZE
> OVERLAYSYMBOL
> syn keyword mapIdentifier PARTIALS POINTS POSITION POSTLABELCACHE
PROCESSING
> syn keyword mapIdentifier REQUIRES RESOLUTION
> syn keyword mapIdentifier SCALE SHADOWCOLOR SHADOWSIZE SHAPEPATH SIZE
> SIZEUNITS STATUS STYLEITEM SYMBOLSCALE SYMBOLSET
> syn keyword mapIdentifier TABLE TEMPLATE TEMPLATEPATTERN TEXT
TILEINDEX
> TILEITEM TITLE TO TOLERANCE TOLERANCEUNITS TRANSFORM TRANSPARENCY
> TRANSPAREN[T] TYPE
> syn keyword mapIdentifier UNITS WMS_ABSTRACT WMS_ACCESSCONSTRAINTS
> WMS_ONLINERESOURCE WMS_SRS WMS_TITLE WRAP
> " General keywords third order
> syn keyword mapKeyword ANNOTATION AUTO BEVEL BITMAP BUTT
> syn keyword mapKeyword CARTOLINE CC CIRCLE CL CR CSV DD DEFAULT
> syn keyword mapKeyword ELLIPSE EMBED FALSE FEET GIANT HILITE INCHES
> syn keyword mapKeyword KILOMETERS LARGE LC LINE LL LR
> syn keyword mapKeyword MEDIUM METERS MILES MITER MULTIPLE MYGIS
NORMAL
> syn keyword mapKeyword OFF OGR ON ONE-TO-MANY ONE-TO-ONE
ORACLESPATIAL
> syn keyword mapKeyword PIXELS PIXMAP POINT POLYGON POSTGIS QUERY
RASTER
> ROUND
> syn keyword mapKeyword SDE SELECTED SIMPLE SINGLE SMALL SQUARE
> syn keyword mapKeyword TINY TRIANGLE TRUE TRUETYPE UC UL UR
> VECTOR WFS WMS
> " keywords for other purposes
> syn keyword mapTypedef SELECTION
> " Comment
> syn match mapComment "#.*"
> " Strings (single- and double-quote)
> syn region mapString start=+"+ skip=+\\\\\|\\"+ end=+"+
> syn region mapString start=+'+ skip=+\\\\\|\\'+ end=+'+
> " Numbers and hexidecimal values
> syn match mapNumber "-\=\<[0-9]*\>"
> syn match mapNumber "\<0x[abcdefABCDEF0-9]*\>"
> " Operators
> syn match mapOperator "EQ"
> syn match mapOperator "[><|\=&!$/\\()\[\]]"
> " Define the default highlighting.
> " For version 5.7 and earlier: only when not done already
> " For version 5.8 and later: only when an item doesn't have highlighting
yet
> if version >= 508 || !exists("did_map_syn_inits")
> if version < 508
> let did_map_syn_inits = 1
> command -nargs=+ HiLink hi link <args>
> else
> command -nargs=+ HiLink hi def link <args>
> endif
> HiLink mapComment Comment
> HiLink mapKeyword Keyword
> HiLink mapIdentifier Identifier
> HiLink mapDefine Define
> HiLink mapTypedef Typedef
> HiLink mapNumber Number
> HiLink mapString String
> HiLink mapOperator Operator
> delcommand HiLink
> endif
> let b:current_syntax = "map"
> " vim: ts=8
> _________________________________________________________________
> Tired of spam? Get advanced junk mail protection with MSN 8.
> http://join.msn.com/?page=features/junkmail
> [attachment "map.vim" deleted by Tyler Mitchell/Lignum]
