[Mapserver-users] querybyattributes logical expression
Ryan, Adam
ARyan at co.linn.or.us
Wed May 26 14:24:18 EDT 2004
Using "([AREA] > 4000000)" works for me. Silly question: Are you sure your
Area field is numeric?
Adam
-----Original Message-----
Sent: Wednesday, May 26, 2004 10:54 AM
To: Mapserver-users at lists.gis.umn.edu
Cc: Eric Bridger
Subject: Re: [Mapserver-users] querybyattributes logical expression
I have also used different operators in class expressions. I tried your
suggestion but it did not work. Strangely the single quotes are needed
regardless of the data type of the field. So that the following query does
work:
$queryString = "('[AREA]' = '10')"
$queryItem = 'AREA';
> > $map->querybyattributes($queryitem,$queryString,MS_MULTIPLE);
----- Original Message -----
Date: Wednesday, May 26, 2004 4:03 am
> At 11:11 PM 05/25/2004 -0700, AARON KONING wrote:
> >Hi List,
> >Just wondering if anyone has had success using querybyattributes with
> >the '>', '<', '>=', '<=' operators? I have
> been using the 'NOT', 'AND', 'OR',
> >and '=' operators with success.
> >The following statement fails:
> > $queryString = "('[AREA]' > '10')"
> I haven't used querybyattributes() but have use comparison
> operators in CLASS EXPRESSION's.
> I would try:
> "([AREA] > 10)" i.e. these are number values not strings.
> Mapserver-users mailing list Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
