[Mapserver-users] multiple symbols in the same class
Jean-Denis Giguere
jdenisgiguere at fastmail.fm
Wed May 26 21:19:11 EDT 2004
This is an OpenPGP/MIME signed message (RFC 2440 and 3156)
--------------enig8ED2F4B6DBB6FB66B589899C
Content-Type: text/plain; charset=ISO-8859-1; format=flowed
Content-Transfer-Encoding: 8bit
Eduardo Patto Kanegae wrote:
> is there a way to define 2 symbologies for the same class, of the same layer, inside a CGI mapserver application without creation two layers with the same name?
> I mean, I wanna use a vector SYMBOL from the scale 1:250000 to 1:10000 and from 1:9999 to 1:1000 I want to use a PIXMAP symbol.
You can specify the minimal and maximal scale for a class with MINSCALE
and MAXSCALE. The syntax seems to be the same as for layer. I use this
to specify when display primary and secondary elements of a layer.
Maybye it is possible to specify different style for each class.
Hope this can help,
Jean-Denis
> thanks
> http://www.consultoria.eti.br
> UIN: 303747254
> I Encontro Nacional de Usuários MapServer - http://mapserver.cttmar.univali.br/encontro2004
> Projeto MapServer Brasil - http://mapserver.cttmar.univali.br
> ***Fim da Mensagem / End of Message ***
> Mapserver-users mailing list
> Mapserver-users at lists.gis.umn.edu
> http://lists.gis.umn.edu/mailman/listinfo/mapserver-users
Content-Type: application/pgp-signature; name="signature.asc"
Content-Description: OpenPGP digital signature
Content-Disposition: attachment; filename="signature.asc"
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://enigmail.mozdev.org
iD8DBQFAtUIUmQkurNcFNt4RAlrsAJ9ksOVM1k4/3Xh9Ac63bfBN61GFIwCdGeNk
l/xn7ydE9TXOg710iUFI4PQ=
=DP4E
-----END PGP SIGNATURE-----
--------------enig8ED2F4B6DBB6FB66B589899C--
