[Mapserver-users] virtual spatial data
Zak James zak-ms at hoppsan.org
Thu May 27 08:38:02 PDT 2004
On May 27, 2004, at 11:10 AM, Chip Hankley wrote:
> With respect to MS version, is there anyway to figure out which version
> of GDAL the exe was compiled with?
Try dependency walker (http://www.dependencywalker.com/) - it should
tell you the versions of any components used by the mapserver
executable. We're actively working on this problem and will forward
anything we discover to the list.
Can you confirm that you are able to get back your data via the virtual
driver (using an ovf file) from the command line? This is different
from using ogrinfo with the odbc driver directly.
i.e.
not
ogrinfo odbc:<db connect>
but
ogrinfo -ro config.ovf
I apologize if I'm asking you to repeat yourself!
zak
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
More information about the MapServer-users mailing list
