[Mapserver-users] Setup errors
Andrew Rich
devel at itdownunder.com.au
Mon May 31 11:28:57 EDT 2004
This is a multi-part message in MIME format.
------=_NextPart_000_0004_01C44777.D09FF240
Content-Type: text/plain;
charset="us-ascii"
Content-Transfer-Encoding: 7bit
Fixed it!
I found the older version of libpng.so.2 install in /usr/lib while the
new version was in /usr/local/lib
Deleted the older version and working now.
Andrew
-----Original Message-----
[mailto:mapserver-users-admin at lists.gis.umn.edu] On Behalf Of Andrew
Rich
Sent: Sunday, 30 May 2004 11:45 PM
To: mapserver-users at lists.gis.umn.edu
Subject: [Mapserver-users] Setup errors
Hello all
I am setting up Mapserver for the first time and require some help when
I have trouble.
At the moment I believe Mapserv is compiling ok but one of the
dependencies has a problem.
Linux Platform (RH 7.3)
GD 2.0.22
Freetype 1.3.1
Jpeg-6b
Libpng 1.2.5
Mapserver 4.2
Proj 4.4.7
Xpm-3.4k
Zlib 1.2.1
When running the demo site I receive the following error in the HTTPD
(Apache 1.3.27) log:
libpng warning: Application was compiled with png.h from libpng-1.2.5
libpng warning: Application is running with png.c from libpng-1.0.14
gd-png: fatal libpng error: Incompatible libpng version in application
and library
[Sun May 30 23:27:51 2004] [error] [client 203.217.43.110] Premature end
of script headers: /var/www/cgi-bin/mapserv
Initially I had these but recompiled Libpng-1.2.5 and then fixed a
libpng12.so.0 dependancy not found problem:
The /usr/local/lib contains the following:
[root at tanami src]# ls -al /usr/local/lib/libpng*
-rw-r--r-- 1 root root 162990 May 30 22:23
/usr/local/lib/libpng12.a
lrwxrwxrwx 1 root root 13 May 30 22:23
/usr/local/lib/libpng12.so -> libpng12.so.0
lrwxrwxrwx 1 root root 19 May 30 22:23
/usr/local/lib/libpng12.so.0 -> libpng12.so.0.1.2.5
-rwxr-xr-x 1 root root 196402 May 30 22:23
/usr/local/lib/libpng12.so.0.1.2.5
lrwxrwxrwx 1 root root 10 May 30 22:23
/usr/local/lib/libpng.a -> libpng12.a
lrwxrwxrwx 1 root root 11 May 30 22:23
/usr/local/lib/libpng.so -> libpng.so.3
lrwxrwxrwx 1 root root 11 May 30 22:25
/usr/local/lib/libpng.so.2 -> libpng.so.3
lrwxrwxrwx 1 root root 17 May 30 22:23
/usr/local/lib/libpng.so.3 -> libpng.so.3.1.2.5
/usr/local/lib/libpng.so.3.1.2.5
A ldd mapserv gives the following result:
[root at tanami src]# ldd /var/www/cgi-bin/mapserv
libgd.so.2 => /usr/local/lib/libgd.so.2 (0x4002b000)
libjpeg.so.62 => /usr/lib/libjpeg.so.62 (0x40064000)
libfreetype.so.6 => /usr/lib/libfreetype.so.6 (0x40082000)
libpng.so.2 => /usr/lib/libpng.so.2 (0x400c1000)
libz.so.1 => /usr/lib/libz.so.1 (0x400e3000)
libtiff.so.3 => /usr/lib/libtiff.so.3 (0x400f1000)
libm.so.6 => /lib/i686/libm.so.6 (0x40134000)
libc.so.6 => /lib/i686/libc.so.6 (0x42000000)
libXpm.so.4 => /usr/X11R6/lib/libXpm.so.4 (0x40157000)
libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x40165000)
libpng12.so.0 => /usr/local/lib/libpng12.so.0 (0x4023a000)
/lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
libdl.so.2 => /lib/libdl.so.2 (0x40267000)
A locate on png.h: (I removed .html files from paste)
[root at tanami src]# locate png.h
/usr/lib/interchange-4.9.9/foundation/pages/survey/graph.png.html
/usr/lib/interchange-4.9.8-200309280658/dist/foundation/pages/survey/gra
ph.png.html
/usr/include/mozilla-1.0.2/png/png.h
/usr/include/png.h.old
/usr/local/include/libpng/png.h
/usr/local/include/png.h
/usr/src/libpng-1.2.5/contrib/gregbook/readpng.h
/usr/src/libpng-1.2.5/contrib/gregbook/writepng.h
/usr/src/libpng-1.2.5/png.h
A locate on png.c:
[root at tanami src]# locate png.c
/usr/src/gd-2.0.22/gd_png.c
/usr/src/gd-2.0.22/gd2topng.c
/usr/src/gd-2.0.22/gdparttopng.c
/usr/src/gd-2.0.22/gdtopng.c
/usr/src/gd-2.0.22/webpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/readpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/wpng.c
/usr/src/libpng-1.2.5/contrib/gregbook/writepng.c
/usr/src/libpng-1.2.5/contrib/pngminus/pnm2png.c
/usr/src/libpng-1.2.5/png.c
/usr/src/libpng-1.2.5/projects/borland/libpng.cpp
So can someone please give me an idea what to look for next.
Thank you
Andrew Rich
Content-Type: text/html;
charset="us-ascii"
Content-Transfer-Encoding: quoted-printable
<html xmlns:o=3D"urn:schemas-microsoft-com:office:office" =
xmlns:w=3D"urn:schemas-microsoft-com:office:word" =
xmlns:st1=3D"urn:schemas-microsoft-com:office:smarttags" =
xmlns=3D"http://www.w3.org/TR/REC-html40">
<head>
<META HTTP-EQUIV=3D"Content-Type" CONTENT=3D"text/html; =
charset=3Dus-ascii">
<meta name=3DProgId content=3DWord.Document>
<meta name=3DGenerator content=3D"Microsoft Word 10">
<meta name=3DOriginator content=3D"Microsoft Word 10">
<link rel=3DFile-List href=3D"cid:filelist.xml at 01C44777.CEA310D0">
<o:SmartTagType =
namespaceuri=3D"urn:schemas-microsoft-com:office:smarttags"
name=3D"date"/>
<o:SmartTagType =
name=3D"time"/>
<!--[if gte mso 9]><xml>
<o:OfficeDocumentSettings>
<o:DoNotRelyOnCSS/>
</o:OfficeDocumentSettings>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:DocumentKind>DocumentEmail</w:DocumentKind>
<w:EnvelopeVis/>
<w:Compatibility>
<w:BreakWrappedTables/>
<w:SnapToGridInCell/>
<w:WrapTextWithPunct/>
<w:UseAsianBreakRules/>
</w:Compatibility>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
</xml><![endif]--><!--[if !mso]>
<style>
st1\:*{behavior:url(#default#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Tahoma;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:1627421319 -2147483648 8 0 66047 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0cm;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:purple;
span.EmailStyle17
{mso-style-type:personal;
mso-style-noshow:yes;
mso-ansi-font-size:10.0pt;
mso-bidi-font-size:10.0pt;
font-family:Arial;
mso-ascii-font-family:Arial;
mso-hansi-font-family:Arial;
mso-bidi-font-family:Arial;
color:windowtext;}
span.EmailStyle18
font-family:Arial;
color:navy;}
span.EmailStyle19
{mso-style-type:personal-reply;
font-family:Arial;
color:navy;}
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
@page Section1
{size:612.0pt 792.0pt;
margin:72.0pt 90.0pt 72.0pt 90.0pt;
mso-header-margin:35.4pt;
mso-footer-margin:35.4pt;
mso-paper-source:0;}
div.Section1
{page:Section1;}
</style>
<!--[if gte mso 10]>
<style>
/* Style Definitions */=20
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
</style>
<![endif]-->
</head>
<body lang=3DEN-US link=3Dblue vlink=3Dpurple =
style=3D'tab-interval:36.0pt'>
<div class=3DSection1>
<p class=3DMsoNormal><font size=3D2 color=3Dnavy face=3DArial><span =
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Fixed =
it!<o:p></o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'><o:p> </o:p></span></font></p>
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>I found the older version of =
libpng.so.2
install in /<span class=3DSpellE>usr</span>/lib while the new version =
was in /<span
class=3DSpellE>usr</span>/local/lib<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Deleted the older version and =
working now.<o:p></o:p></span></font></p>
style=3D'font-size:
style=3D'font-size:
10.0pt;font-family:Arial;color:navy'>Andrew<o:p></o:p></span></font></p>
style=3D'font-size:
<p class=3DMsoNormal style=3D'margin-left:36.0pt'><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'>-----Original =
Message-----<br>
<b><span style=3D'font-weight:bold'>From:</span></b> =
[mailto:mapserver-users-admin at lists.gis.umn.edu] <b><span =
bold'>On Behalf Of </span></b>Andrew Rich<br>
<b><span style=3D'font-weight:bold'>Sent:</span></b> =
</span></font><st1:date
Month=3D"5" Day=3D"30" Year=3D"2004"><font size=3D2 face=3DTahoma><span =
style=3D'font-size:
10.0pt;font-family:Tahoma'>Sunday, 30 May =
2004</span></font></st1:date><font
style=3D'font-size:10.0pt;font-family:Tahoma'> </span></font><st1:time
Hour=3D"23" Minute=3D"45"><font size=3D2 face=3DTahoma><span =
font-family:Tahoma'>11:45 PM</span></font></st1:time><font size=3D2 =
face=3DTahoma><span
style=3D'font-size:10.0pt;font-family:Tahoma'><br>
<b><span style=3D'font-weight:bold'>To:</span></b>
mapserver-users at lists.gis.umn.edu<br>
<b><span style=3D'font-weight:bold'>Subject:</span></b> =
errors</span></font></p>
<p class=3DMsoNormal style=3D'margin-left:36.0pt'><font size=3D3
face=3D"Times New Roman"><span =
style=3D'font-size:12.0pt'><o:p> </o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Hello =
all<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><o:p> </o:p></span></fo=
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>I am setting up Mapserver =
for the
first time and require some help when I have =
trouble.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>At the moment I believe =
Mapserv is
compiling ok but one of the dependencies has a =
problem.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Linux Platform (RH =
7.3)<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>GD =
2.0.22<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Freetype =
1.3.1<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Jpeg-6b<o:p></o:p></span></f=
ont></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Libpng =
1.2.5<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Mapserver =
4.2<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Proj =
4.4.7<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Xpm-3.4k<o:p></o:p></span></=
font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Zlib =
1.2.1<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>When running the demo site =
I receive
the following error in the HTTPD (Apache 1.3.27) =
log:<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>libpng warning: Application =
was
compiled with png.h from libpng-1.2.5<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>libpng warning: =
Application<span
style=3D'mso-spacerun:yes'> </span>is<span =
</span>running with png.c from =
libpng-1.0.14<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>gd-png:<span
style=3D'mso-spacerun:yes'> </span>fatal libpng error: =
Incompatible libpng
version in application and library<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>[Sun May 30 =
Hour=3D"23" Minute=3D"27"><font size=3D2 face=3DArial><span =
font-family:Arial'>23:27:51</span></font></st1:time><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'> 2004] [error] [client
203.217.43.110] Premature end of script headers: =
/var/www/cgi-bin/mapserv<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Initially I had these but =
recompiled
Libpng-1.2.5 and then fixed a libpng12.so.0 dependancy not found =
problem:<span
style=3D'mso-spacerun:yes'> </span><o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>The /usr/local/lib contains =
the
following:<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>[root at tanami src]# ls -al
/usr/local/lib/libpng*<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>-rw-r--r--<span
style=3D'mso-spacerun:yes'> </span>1 root<span
style=3D'mso-spacerun:yes'> </span>root<span
style=3D'mso-spacerun:yes'> =
</span>162990 May
30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>22:23</span></font></st1:tim=
e><font
/usr/local/lib/libpng12.a<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>lrwxrwxrwx<span
style=3D'mso-spacerun:yes'> &nbs=
p;
</span>13 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng12.so -> =
libpng12.so.0<o:p></o:p></span></font></p>
face=3DArial><span
p;
</span>19 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng12.so.0 -> =
libpng12.so.0.1.2.5<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>-rwxr-xr-x<span
style=3D'mso-spacerun:yes'> </span><span
style=3D'mso-spacerun:yes'> </span>196402 May 30 =
Hour=3D"22" Minute=3D"23"><font size=3D2 face=3DArial><span =
font-family:Arial'>22:23</span></font></st1:time><font size=3D2 =
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'> =
/usr/local/lib/libpng12.so.0.1.2.5<o:p></o:p></span></font></p>
face=3DArial><span
p;
</span>10 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng.a -> libpng12.a<o:p></o:p></span></font></p>
face=3DArial><span
p;
</span>11 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng.so -> libpng.so.3<o:p></o:p></span></font></p>
face=3DArial><span
p;
</span>11 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"25"><font =
size=3D2
style=3D'font-size:10.0pt;font-family:Arial'>22:25</span></font></st1:tim=
e><font
/usr/local/lib/libpng.so.2 -> =
face=3DArial><span
p;
</span>17 May 30 </span></font><st1:time Hour=3D"22" Minute=3D"23"><font =
size=3D2
e><font
/usr/local/lib/libpng.so.3 -> =
libpng.so.3.1.2.5<o:p></o:p></span></font></p>
face=3DArial><span
</span>196402 May
face=3DArial><span
e><font
/usr/local/lib/libpng.so.3.1.2.5<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>A ldd mapserv gives the =
following
result:<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>[root at tanami src]# ldd
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'><span
</span>libgd.so.2 =3D> /usr/local/lib/libgd.so.2 =
(0x4002b000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libjpeg.so.62 =3D> /usr/lib/libjpeg.so.62 =
(0x40064000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libfreetype.so.6 =3D> /usr/lib/libfreetype.so.6 =
(0x40082000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libpng.so.2 =3D> /usr/lib/libpng.so.2 =
(0x400c1000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libz.so.1 =3D> /usr/lib/libz.so.1 =
(0x400e3000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libtiff.so.3 =3D> /usr/lib/libtiff.so.3 =
(0x400f1000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libm.so.6 =3D> /lib/i686/libm.so.6 =
(0x40134000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libc.so.6 =3D> /lib/i686/libc.so.6 =
(0x42000000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libXpm.so.4 =3D> /usr/X11R6/lib/libXpm.so.4 =
(0x40157000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libX11.so.6 =3D> /usr/X11R6/lib/libX11.so.6 =
(0x40165000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libpng12.so.0 =3D> /usr/local/lib/libpng12.so.0 =
(0x4023a000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>/lib/ld-linux.so.2 =3D> /lib/ld-linux.so.2 =
(0x40000000)<o:p></o:p></span></font></p>
face=3DArial><span
</span>libdl.so.2 =3D> /lib/libdl.so.2 =
(0x40267000)<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>A locate on png.h: (I =
removed .html
files from paste)<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>[root at tanami src]# locate =
png.h<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/lib/interchange-4.9.9/f=
oundation/pages/survey/graph.png.html<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/lib/interchange-4.9.8-2=
00309280658/dist/foundation/pages/survey/graph.png.html<o:p></o:p></span>=
</font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/include/mozilla-1.0.2/p=
ng/png.h<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/include/png.h.old<o:p><=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/local/include/libpng/pn=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/local/include/png.h<o:p=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/libpng-1.2.5/contri=
b/gregbook/readpng.h<o:p></o:p></span></font></p>
face=3DArial><span
b/gregbook/writepng.h<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/libpng-1.2.5/png.h<=
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>A locate on =
png.c:<o:p></o:p></span></font></p>
face=3DArial><span
png.c<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/gd-2.0.22/gd_png.c<=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/gd-2.0.22/gd2topng.=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/gd-2.0.22/gdparttop=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/gd-2.0.22/gdtopng.c=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/gd-2.0.22/webpng.c<=
face=3DArial><span
b/gregbook/readpng.c<o:p></o:p></span></font></p>
face=3DArial><span
b/gregbook/wpng.c<o:p></o:p></span></font></p>
face=3DArial><span
b/gregbook/writepng.c<o:p></o:p></span></font></p>
face=3DArial><span
b/pngminus/pnm2png.c<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/libpng-1.2.5/png.c<=
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>/usr/src/libpng-1.2.5/projec=
ts/borland/libpng.cpp<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>So can someone please give =
me an
idea what to look for next.<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Thank =
you<o:p></o:p></span></font></p>
face=3DArial><span
style=3D'font-size:10.0pt;font-family:Arial'>Andrew =
Rich<o:p></o:p></span></font></p>
face=3DArial><span
nt></p>
</div>
</body>
</html>
------=_NextPart_000_0004_01C44777.D09FF240--
