Interlaced reference maps
Romolo Manfredini
romoloman at HOTMAIL.COM
Tue Nov 2 03:13:28 EST 2004
> I think you need to be more specific about "whatever setting I place in
the
> mapfile". Skimming through the reference file code it looks like the
> interlacing should be controlled by the main map object imagetype. What
> have you set IMAGETYPE to? Have you tried defining a custom outputformat
> to produce what you want?
To be more specific I have the following in my map file
IMAGETYPE PNG
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
FORMATOPTION "INTERLACE=OFF"
END
The reference image is a png 24 bits uninterlaced.
I get an interlaced reference either using the cgi either using
php/mapscript.
Best regards
Romolo
