Slight rendering problem with 4.4-beta1 ...
Jean-Francois Doyon
Jean-Francois.Doyon at CCRS.NRCAN.GC.CA
Wed Nov 3 13:35:09 EST 2004
Steve,
I turned all layers off except the one where I noticed the problem, and the
problem still occurs.
I'll send the screenshot under seperate cover.
J.F.
-----Original Message-----
From: Steve Lime [mailto:steve.lime at dnr.state.mn.us]
Sent: November 3, 2004 1:01 PM
To: Jean-Francois.Doyon at CCRS.NRCan.gc.ca; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] Slight rendering problem with
4.4-beta1 ...
> Could it be related to the labelling cache? In what order are labels
drawn?
> If from top-left to bottom-right, then it would seem that it's alway
sthe
> "last" label that does this ... I'll try more maps to see if I detect
a
> pattern (It's a bit of work because I have to convert the mapfile
from
> 3.6.6).
J.F.: Labeling is done in:
- reverse order of how features appear in the dataset (last into the
cache is first drawn)
- reverse layer order (last layer is labeled first)
If you make up a mapfile with just the layer showing the problem does
the problem
persist?
Steve
