The use of '
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Fri Nov 5 10:30:36 EST 2004
Daniele Margotti wrote:
> I use shape files, and in .DBF files I have string values with apostrophes
> inside (e.g.: "Cava de' Tirreni", "Via Dell'Artigianato", and so on).
> When I query my map, MapServer substitutes all apostrophes with the
> string "'" (and prints "Cava de' Tirreni" or "Via
> Dell'Artigianato").
How do you query your map? Are you using the mapserv CGI with the query
templates or some other mechanism such as WMS, WFS,... ?
> In fact, "'" is not a valid HTML entity reference, as you can see
> here:
> http://fishbowl.pastiche.org/2003/07/01/the_curse_of_apos
> Do I have to modify mapstring.c and recompile all, or can I tell MapServer
> (for example, with a flag in .map file) to not substitute apostrophes?
Um... it's the first time I hear of this. For the benefit of other
readers who didn't follow the link above: ' is valid in XML and in
XHTML but not in good'old HTML. :(
Could you please file a bug about this in the mapserver bugzilla?
> P.S.: WHY can't I still use Outlook to post to the list?
> I've regularly subscribed, but it seems I can only post via webinterface...
I'd suggest that you contact Tom Burk (teb at mallit.fr.umn.edu), he's
the contact with the listserv administrators.
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
