AW: [UMN_MAPSERVER-USERS] Oraclspatial OGR+OCI FeatureInfoRequest
Böcke, Max (init)
Max.Boecke at INIT.DE
Wed Nov 24 05:52:04 EST 2004
Thanks.
I've found the mistake. It was an error in the database table.
Important is, that you have to write an entry in the database or mapfile.
You need an Primary Key named OGR_FID in your table.
Here my Configuration:
LAYER
NAME "Badeg"
TYPE POINT
STATUS DEFAULT
CONNECTIONTYPE OGR
CONNECTION "OCI:user/pass at DbName"
DATA "select ID as OGR_FID, geometrie, Name, Gemeinde, Kreis from hydbasis_badegewaesser"
#MAXSCALE 300001
HEADER "Templates/Badegewaesser_header.html"
FOOTER "Templates/Badegewaesser_footer.html"
TOLERANCE 10
CLASS
SYMBOL 3
COLOR 0 0 200
SIZE 4
TEMPLATE "Templates/Badegewaesser_query.html"
END
END
Greetings
Max Böcke
-----Ursprüngliche Nachricht-----
Von: bluecarto at free.fr [mailto:bluecarto at free.fr]
Gesendet: Mittwoch, 24. November 2004 11:44
An: Böcke, Max (init)
Betreff: Re: [UMN_MAPSERVER-USERS] Oraclspatial OGR+OCI
FeatureInfoRequest
A bug has been reported for the same issue I think.
http://208.24.120.44/show_bug.cgi?id=657
Pierre GIRAUD
camptocamp.com
Selon "Böcke, Max (init)" <Max.Boecke at INIT.DE>:
> Hello Community,
> I've got a little problem. I try to have a FeatureInfoRequest using
> Connectiontype OGR
> Connection "OCI:user/pw at db"
> My Mapfile_Layer_configuration:
> LAYER
> NAME "Badegew"
> TYPE POINT
> STATUS DEFAULT
> CONNECTIONTYPE OGR
> CONNECTION "OCI:xxxx/xxx at xxx"
> DATA "wab_staedte_umn"
> #MAXSCALE 300001
> HEADER "Templates/staedte_header.html"
> FOOTER "Templates/staedte_footer.html"
> LABELITEM "Name"
> TOLERANCE 3
> CLASS
> SYMBOL 7
> COLOR 255 0 0
> SIZE 5
> TEMPLATE "Templates/staedte_query.html"
> LABEL
> COLOR 0 0 0
> SIZE TINY
> POSITION UC
> END
> END
> END #End Layer
> When the InfoRequest is shown in the IE, the mapserver send back the first
> entry from the oracle spatial table, whatever I 've snapped in the Map. He
> shows the same entry of the DB table.
> Sorry for bad english.:-(
> regards from Berlin (Germany)
> Max Böcke
> ]init[ Aktiengesellschaft Rosenthaler Strasse 13
> für digitale Kommunikation D-10119 Berlin
> http://www.init.de/ tel: +49 (30) 97 006 259
> mailto:Max.Boecke at init.de fax: +49 (30) 97 006 459
