msProcessProjection(): unknown projection id
Frank Warmerdam
warmerdam at POBOX.COM
Wed Nov 24 14:17:06 EST 2004
joerg pfeiffer wrote:
> hello,
> i installed mapserver with the lingis rpms. Everything seemed to be
> fine, but when I am running my .phtml files I get the error:
> I tried to change the projection, I completely deleted the projection, I
> completely deleted all the contents of the whole file, but nothing
> happens. I always get this error.
Joerg,
The message means an unrecognised value was passed to pj_init() for the
proj=<value> argument of a projection definition. This is quite unusual.
It is almost certain that somewhere in your .map file or your PHP script
there will be something setting a projection and for some reason doing
so improperly.
If you are willing to try it out, you might want to add a debug message in
proj/src/pj_init.c near the line:
if (!s) { pj_errno = -5; goto bum_call; }
Change this to:
if (!s) {
fprintf( stderr, "unknown proj=%s\n", name);
Of course, you will need to download, build and install a new PROJ.4
from source to make this change.
Good luck,
and watch the world go round - Rush | Geospatial Programmer for Rent
