Question on queryByAttributes - multiple fields
Sean Gillies
sgillies at FRII.COM
Tue Nov 30 12:00:16 EST 2004
Cord,
Here's something to try (python example):
# execute queryByAttributes ...
results = layer.getResults()
The 'results' variable will either be a reference to the
layer's result set or be NULL if the query returned nothing.
The reason why it returned nothing may be found in the
mapserver error stack
if results == None:
error = mapscript.errorObj()
if error:
print error.code, error.message, error.routine
# continue into the stack
while 1:
error = error.next()
if error == None: break
else:
Actually, for Python/Java/Ruby, MapServer errors become language
exceptions. For Perl, which has no built-in exceptions, users
have to program their own error stack inspection.
Sean
On Nov 30, 2004, at 9:14 AM, Cord Thomas wrote:
> Sean,
> Thank you. If you'd like participation in the howTo, let me know. I
> would like to contribute non-trivial examples as i put them together.
> Given your discovery - i feel there may be a bug in implementation
> then.
> I am unsure why my query results in getNumResults() = 0 though when
> executed directly against the database, it returns 1 record.
> Cord
>> My responses inline ...
>> On Nov 29, 2004, at 6:15 PM, Cord Thomas wrote:
>>> Hey Sean
>>> Thank you for this definitive answer. I have a few observations:
>>> 1 - as i said, if i see the query dump from mapserver when i forgot
>>> to
>>> give my account select permissions, i saw the following statement:
>>> DECLARE mycursor BINARY CURSOR FOR SELECT
>>> stateid,name::
>>> text,asbinary(force_collection(force_2d(wkb_geometry)),'NDR'),OID::
>>> text
>>> from incorpbound WHERE (stateid='ME' and name='Camden') and
>>> (wkb_geometry
>>> && setSRID( 'BOX3D(-125 23,-66
>>> 50.5)'::BOX3D,find_srid('','incorpbound','wkb_geometry') ))
>>> this would imply mapserver is correctly parsing my query - AND - if i
>>> try
>>> to execute this query against postgresql, it does return results - i
>>> get
>>> all excited by this.
>>> 2 - since query parsing is not left to mapserver (we have to provide
>>> the
>>> exact syntax) - there is no reason MS couldnt handle multiple field
>>> criteria.
>> I looked again at the code underneath mapserver queries. Here's what
>> goes on under the hood: the queried layer has its 'filteritem'
>> temporarily
>> set to the 'qitem' from the query method, and its 'filter' temporarily
>> set to the 'qstring'. Then the features are filtered and indexes to
>> the
>> features become the query result set.
>> So yes, you can do a multi-attribute query. For a RDBMS data source,
>> your qstring can be almost any SQL where clause, and for shapefile or
>> OGR sources you can do complicated mapserver expressions like
>> qstring = "([att1] > 0 and [att2] > 0)"
>> I guess my querying HOWTO needs major revision already :)
>>> 3 - i see no performance issues or other technical hurdles that would
>>> prevent the execution by MS of this request - unless actually it is
>>> tied
>>> to how this information gets back into the TEMPLATE object or is used
>>> by
>>> LABELs - both issues i am unclear on (like why a TEMPLATE is
>>> /required/ by
>>> MS for queries)
>> The template is an artifact from the CGI mode, since that's how the
>> results are delivered. I'm constantly debating with other developers
>> over eliminating this artifact from mapscript.
>>> 4 - I understood the MS_SINGLE vs MULTIPLE - though i still need to
>>> learn
>>> how best to work with this (one problem i have is that a city's
>>> boundaries
>>> may come in more than 1 record - but i really just want 1 result -
>>> something i have to tinker with on my end) - thanks for the
>>> explanation.
>>> I look forward to reading more on documentation and if i can help,
>>> please
>>> let me know. I am working on a prototype public participation web
>>> application and i need a feature like this to work, and work quickly
>>> (application performance, not how quickly i need 4.4 released). The
>>> two
>>> fields are indexed and i really can't imagine that saving a query and
>>> reloading it is going to be efficient, but i look forward to possibly
>>> hearing from Adam. As an alternative, i could query on the most
>>> restrictive field and then iterate over the results until i find the
>>> value
>>> of the less restrictive field - though ugly, i guess that is an
>>> alternative.
>> Since your data is in PostgreSQL/PostGIS, you can always go directly
>> to the database when you need.
>> cheers,
>> Sean
