Problems with multiple join
Wim Blanken
w.blanken at GEON.NL
Sun Oct 3 07:40:14 PDT 2004
Hello list,
We've had some problems using the CGI Mapserver one-to-many join function
to a dbf file.
In the wiki there is a good introduction to this functionality but it
seems not to work perfectly with the 4.2.x edition of mapserver.
I did everything according to this document but I got a mapserver
error (mapserv.exe error). After an hour or so I came to the conclusion
that the sub-template (the template with the joined data) should not
contain carriage returns. So if you type it all in once sentence it works
very good but if you use an enter in the code the error is generated.
I did not test this on linux......
Is this a bug?
Regards,
Wim Blanken
More information about the MapServer-users
