gdalindex question
    Simpson
    asimpson at I-55.COM
    Tue Oct  5 04:59:38 PDT 2004
Try commenting out the CLASS definition...
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
Behalf Of Dylan Beaudette
Sent: Monday, October 04, 2004 3:59 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] gdalindex question
Not many people out there with this name!
Nice to meet you.
...well i tried your suggestions, but no change in the output.
here is my layer defs now:
LAYER
 NAME "DOQQ_index"
 TYPE RASTER
 TILEINDEX
"/home/dylan/public_html/mapserver/mapunit/data/imagery/doqq/tiled/doqq_inde
x.shp"
(line wrapped by email client)
 TILEITEM "location"
 #DATA "imagery/doqq/tiled/o38122f1nw.tif.temp.tiff"
 STATUS DEFAULT
 #ignore black pixels (treat as transparent)
 OFFSITE 0 0 0
 #render the rest of the pixel values!
 CLASS
  NAME "DOQQ"
 END
END
not sure what to try next, but it must be something simple!
thanks,
Dylan
On Monday 04 October 2004 01:50 pm, Dylan Keon wrote:
> Hi Dylan :-)
> After upgrading to 4.2.x or so, I found I had to use absolute paths for
> tileindexes.  That is, SHAPEPATH wouldn't work with my TILEINDEX
> declaration.  So, try:
>    TILEINDEX "/full/path/to/imagery/doqq/tiled/doqq_index.shp"
> and see if that makes a difference.  Also, are you sure it's TILEITEM
> "Location" instead of "location"?  It may be case sensitive, I can't
> remember.
> --Dylan
> On 10/04/2004 01:45 PM, Dylan Beaudette wrote:
> > Ed-
> > Thanks for  the quick reply!
> > The mapserver output looks a litte funny because I am displaying the
tile
> > index as a polygon layer, so that I know that it actually exists, and is
> > projected corectly. The labels do look like strange file names, but they
> > are indeed correct...
> > when i attempt to access the rasters individually:
> > ...it works fine:
> > http://169.237.35.250/~dylan/temp/tile_index_with_1_raster.jpg
> > ...but the rasters are not loaded via the TILEINDEX method.
> > here is the updated layer definition (thanks for the OFFSITE idea!!)
> > ----------------snip------------------
> > LAYER
> >  NAME "DOQQ_index"
> >  TYPE RASTER
> >  TILEINDEX "imagery/doqq/tiled/doqq_index.shp"
> >  TILEITEM "Location"
> >  STATUS DEFAULT
> >  OFFSITE 0 0 0
> >  CLASS
> >   NAME "DOQQ"
> >  END
> > END
> > ...still no success with the rasters this way...
> > any ideas?
> > thanks again!
> > Dylan
> > On Monday 04 October 2004 11:37 am, Ed McNierney wrote:
> >>Dylan -
> >>Thanks for asking a well-documented question!
> >>Your MapServer output looks like you're using the tile index layer as a
> >>POLYGON layer, and doesn't seem to match up with the map file fragment
> >> you post (i.e. there's no TYPE POLYGON layer with labels there).  The
> >> filenames that are appearing as labels look a little funny - are you
> >> sure those are the correct filenames?
> >>Also, you're causing all black pixels to be displayed as white, which
> >> won't "remove" them.  You may want to use the OFFSITE statement to
cause
> >> black pixels to be transparent, letting overlapped data show through.
> >>      - Ed
> >>Ed McNierney
> >>President and Chief Mapmaker
> >>TopoZone.com
> >>At 02:18 PM 10/4/2004, Dylan Beaudette wrote:
> >>>Greetings!
> >>>I have a pile of DOQQ images  that i would like to use with my map, and
> >>>wanted to use gdalindex to setup an efficient way for these images to
be
> >>>loaded.
> >>>note that everything is in the same projection.
> >>>after running:
> >>>gdaltindex doqq_index.shp *.tiff
> >>>i am left with a shapfile with entries for all of the images.... seems
> >>> ok.
> >>>...looking at the output in QGIS:
> >>>http://169.237.35.250/~dylan/temp/gdalindex_problems.jpg
> >>>...all seems fine (except for a few mssing images)
> >>>however mapserver is not rendering the tiff files based on the index:
> >>>http://169.237.35.250/~dylan/temp/tile_index.png
> >>>here is my layer defs in my map file:
> >>>----------------------------snip----------------------------
> >>>LAYER
> >>> NAME "DOQQ_index"
> >>> TYPE RASTER
> >>> TILEITEM "Location"
> >>> STATUS DEFAULT
> >>> #remove the black (no_data) pixels!
> >>> CLASSITEM "[pixel]"
> >>> CLASS
> >>>  EXPRESSION ([pixel] == 0 )
> >>>  COLOR 255 255 255
> >>> END
> >>> CLASS
> >>>  NAME "DOQQ"
> >>> END
> >>>END
> >>>any ideas>?
> >>>thanks in advance!!
> >>>Dylan Beaudette
> >>>Soil Science Grad Group
> >>>University of California at Davis
More information about the MapServer-users
