Spatial Query on VirtualSpatial layer
Frank Warmerdam
warmerdam at POBOX.COM
Tue Oct 26 10:40:20 EDT 2004
Blaine Hackett wrote:
> I am using an X and Y field from an ODBC connection to
> show the VSD layer. I can see them but I have not
> successfully queried them. I have tried several
> different query types within the VSD.
> So, to click on them or draw a box around several
> points and have the info about the point returned to
> an html query template is all I am tying to do.
> Does that make sense?
Blaine,
As far as I can tell your approach is reasonable, but then I didn't see
query template. I don't actually use queries very often but as far as I know
they should work the same for VRT/ODBC layers as they do for other OGR layers.
You may need to be careful about uppercase/lower case for attribute names.
Verify the attributes returned by ogrinfo.exe against your .vrt file against
the names for the attributes in your query template.
Sorry I don't have more constructive suggestions.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
