Highlighting a feature on a centered querymap map?
    David Fawcett
    David.Fawcett at STATE.MN.US
    Fri Sep 17 12:34:18 PDT 2004
Rebecca,
Could you also add &mapsize+187+121  to your URL
That may take care of the size issue.
David.
>>> Rebecca Colwell <colwell at GEOG.UMN.EDU> 9/17/2004 2:08:52 PM >>>
Hey everybody,
I'm having two problems with a modified querymap I'm working with.  In
an attempt to recenter to the queried feature, I followed Steve Lime's
advice in a past listserv post, which was:
        Just centering is easy. In you're query template you might
have
        something like:
        <!-- the image -->
        <img src="/cgi-bin/mapserv?map=[map]&mapxy=[shpmidx]+[shpmidy]
        &scale=250000[get_layers]&mode=map">
The result of this is almost exactly what I was looking for, except
for
two things.
1. The querymap map size takes the main map's size, instead of the
smaller size I put in the QUERYMAP part of the .map file (see below).
How can I regain access to my original querymap specifications?
2. The other thing I'd like to have is my selected polygon hilite.
Like
my first question, the hilite feature only works when I don't change
the
img src tag.  Is there a way I can have my cake and eat it too?
Thanks for helping,
~Becky
MAP
   IMAGETYPE      PNG24
   EXTENT         -6153561 4847233 3841846 -3000000
   SIZE           450 294
   SHAPEPATH      "data"
   FONTSET "fonts/fonts.list"
   PROJECTION
     "proj=laea"
     "ellps=clrk66"
     "lat_0=45"
     "lon_0=-100"
   END
   QUERYMAP
      STATUS ON
      STYLE hilite
      COLOR 0 255 0
      SIZE 187 121
   END
More information about the MapServer-users
