Highlighting a feature on a centered querymap map?
David Fawcett
David.Fawcett at STATE.MN.US
Fri Sep 17 16:06:37 EDT 2004
That should have been &mapsize=187+121
David.
David J. Fawcett
MN Office of Environmental Assistance
>>> David Fawcett <David.Fawcett at STATE.MN.US> 9/17/2004 2:34:18 PM >>>
Rebecca,
Could you also add &mapsize+187+121 to your URL
That may take care of the size issue.
David.
>>> Rebecca Colwell <colwell at GEOG.UMN.EDU> 9/17/2004 2:08:52 PM >>>
Hey everybody,
I'm having two problems with a modified querymap I'm working with. In
an attempt to recenter to the queried feature, I followed Steve Lime's
advice in a past listserv post, which was:
Just centering is easy. In you're query template you might
have
something like:
<!-- the image -->
<img src="/cgi-bin/mapserv?map=[map]&mapxy=[shpmidx]+[shpmidy]
&scale=250000[get_layers]&mode=map">
The result of this is almost exactly what I was looking for, except
for
two things.
1. The querymap map size takes the main map's size, instead of the
smaller size I put in the QUERYMAP part of the .map file (see below).
How can I regain access to my original querymap specifications?
2. The other thing I'd like to have is my selected polygon hilite.
Like
my first question, the hilite feature only works when I don't change
the
img src tag. Is there a way I can have my cake and eat it too?
Thanks for helping,
~Becky
MAP
IMAGETYPE PNG24
EXTENT -6153561 4847233 3841846 -3000000
SIZE 450 294
SHAPEPATH "data"
FONTSET "fonts/fonts.list"
PROJECTION
"proj=laea"
"ellps=clrk66"
"lat_0=45"
"lon_0=-100"
END
QUERYMAP
STATUS ON
STYLE hilite
COLOR 0 255 0
SIZE 187 121
END
