Highlighting a feature on a centered querymap map?
Rebecca Colwell
colwell at GEOG.UMN.EDU
Tue Sep 21 13:13:28 EDT 2004
Hey David!
That did it for the centering of each polygon! Thank you so much!
Any ideas on how to highlight the centered polygon?
Thanks again!
~Becky
David Fawcett wrote:
> That should have been &mapsize=187+121
> David.
> David J. Fawcett
> MN Office of Environmental Assistance
>>>>David Fawcett <David.Fawcett at STATE.MN.US> 9/17/2004 2:34:18 PM >>>
> Rebecca,
> Could you also add &mapsize+187+121 to your URL
> That may take care of the size issue.
> David.
>>>>Rebecca Colwell <colwell at GEOG.UMN.EDU> 9/17/2004 2:08:52 PM >>>
> Hey everybody,
> I'm having two problems with a modified querymap I'm working with. In
> an attempt to recenter to the queried feature, I followed Steve Lime's
> advice in a past listserv post, which was:
> Just centering is easy. In you're query template you might
> have
> something like:
> <!-- the image -->
> <img src="/cgi-bin/mapserv?map=[map]&mapxy=[shpmidx]+[shpmidy]
> &scale=250000[get_layers]&mode=map">
> The result of this is almost exactly what I was looking for, except
> for
> two things.
> 1. The querymap map size takes the main map's size, instead of the
> smaller size I put in the QUERYMAP part of the .map file (see below).
> How can I regain access to my original querymap specifications?
> 2. The other thing I'd like to have is my selected polygon hilite.
> Like
> my first question, the hilite feature only works when I don't change
> the
> img src tag. Is there a way I can have my cake and eat it too?
> Thanks for helping,
> ~Becky
> MAP
> IMAGETYPE PNG24
> EXTENT -6153561 4847233 3841846 -3000000
> SIZE 450 294
> SHAPEPATH "data"
> FONTSET "fonts/fonts.list"
> PROJECTION
> "proj=laea"
> "ellps=clrk66"
> "lat_0=45"
> "lon_0=-100"
> END
> QUERYMAP
> STATUS ON
> STYLE hilite
> COLOR 0 255 0
> SIZE 187 121
> END
