asp and mapserver
David Fawcett
David.Fawcett at STATE.MN.US
Mon Sep 27 10:57:47 EDT 2004
Steve,
I am not sure what level of integration your are looking for. There
are some people on this list who have done .asp MapServer projects,
including a wrapper I believe. Hopefully they will speak up.
Depending on your needs, one easy solution is to use .asp to
dynamically build a http request string to a MapServer Server
(mode=map). This string is then used as the source of an image on your
page. I do this with ColdFusion all the time.
It doesn't allow you to query the image, zoom, etc. But it is a great,
cheap, and easy way to add simple dynamic map components to a Web app.
David.
>>> Steve McCrone <ms57 at STREAMYX.COM> 9/27/2004 8:45:12 AM >>>
Is there a way to mix asp and mapserver?
I need to access a database using asp, and then use some of the reults
to
create a GIF using mapserver, and then pass the gif file name created
to
another html page.
The problem is that I cannot seem to mix mapserver and asp.
Thanks
