transparency flash movie OUTPUT_MOVIE=SINGLE/MULTIPLE
Kristjan Annus
kristjan at TARKVARASTUUDIO.EE
Tue Apr 5 05:20:19 EDT 2005
I don't know about seting transparent backgrounds if swf output, but one
solution for you is to put your bitmap background image also to your map
file, and create one single swf output for all of your data.
But I have encountered one problem with mapserver FLASH output too,
thats the size of the swf file, when you use OUTPUT_MOVIE=SINGLE option.
In my case it was about 2-5x of the file size of the same output in jpg
format.
Does anybody know is there some way to decrease the swf output file size?
Kristjan
> Hi List members,
> using the mapserver (two layers) swf/flash output I tried both format
> options:
> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
> Using the first one returns an 'index'-swf from which I can get the two
> layer swf's. This results in 'transparent' movies, that is I can show a
> bitmap behind the movie in the flashplayer.
> When using output SINGLE, I receive the right features, but on an
> non-transparant (white) background (without changing any other option in
> the mapfile)?
> Question:
> - does anyone know IF it is possible to make the SINGLE output movies
> transparent?
> - If yes, please tell me how?
> - Is there another way, then delving in the mapserver cpp code, to
> influence the code within the mapserver-returned-swf-files (for example
> to influence _root or using _parent references)?
> - Is there other flash-output specific documentation other then: the fmv
> flashexample: http://mapserver.gis.umn.edu/user_utilities/fmv.zip?
> Thanks in advance,
> Richard
