transparency flash movie OUTPUT_MOVIE=SINGLE/MULTIPLE
Kristjan Annus
kristjan at TARKVARASTUUDIO.EE
Tue Apr 5 08:06:38 EDT 2005
the link you sent me is usable only from your own computer, so I cant
see it.
I'll send you a link from my Flash test application (player 7 required).
http://www.tartu.ee/bi_kaart/tarkvarastuudio.html
The opening page swf map file is about 100k in size. The same picture in
jpg format in the same application is ~33k.
I use it in another flash movie, but every time when the client is
zooming a map he has to download about 100-300k
new map image.
Kristjan
> Kristjan,
> Thanks I think you're right, I can try to make the bitmap (which is
> actually a call to another OGC mapserver) part of the mapserver
> mapfile. The mapserver then becomes a cascading mapserver?
> Don't know how you call the mapserver, but my swf's are exactly the
> same size as the images I request. I use calls like:
> "http://localhost/cgi-bin/mapserv.exe?map=fnl.map&mode=map&mapext=-20000%20300000%20300000%20620000&mapsize=300%20300"
> which returns a flashmovie of 300x300 to me IF you open the movie in
> the flashplayer. Opening it in a browser shows it indeed 5 times the
> normal size, but using it in another flashmovie is ok.
> Richard
> Kristjan Annus wrote:
>> I don't know about seting transparent backgrounds if swf output, but one
>> solution for you is to put your bitmap background image also to your map
>> file, and create one single swf output for all of your data.
>> But I have encountered one problem with mapserver FLASH output too,
>> thats the size of the swf file, when you use OUTPUT_MOVIE=SINGLE option.
>> In my case it was about 2-5x of the file size of the same output in jpg
>> format.
>> Does anybody know is there some way to decrease the swf output file
>> size?
>> Kristjan
>>> Hi List members,
>>> using the mapserver (two layers) swf/flash output I tried both format
>>> options:
>>> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>>> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>> Using the first one returns an 'index'-swf from which I can get the two
>>> layer swf's. This results in 'transparent' movies, that is I can show a
>>> bitmap behind the movie in the flashplayer.
>>> When using output SINGLE, I receive the right features, but on an
>>> non-transparant (white) background (without changing any other
>>> option in
>>> the mapfile)?
>>> Question:
>>> - does anyone know IF it is possible to make the SINGLE output movies
>>> transparent?
>>> - If yes, please tell me how?
>>> - Is there another way, then delving in the mapserver cpp code, to
>>> influence the code within the mapserver-returned-swf-files (for example
>>> to influence _root or using _parent references)?
>>> - Is there other flash-output specific documentation other then: the
>>> fmv
>>> flashexample: http://mapserver.gis.umn.edu/user_utilities/fmv.zip?
>>> Thanks in advance,
>>> Richard
