transparency flash movie OUTPUT_MOVIE=SINGLE/MULTIPLE
    Richard Duivenvoorde
    richard at DUIF.NET
    Tue Apr  5 07:49:20 PDT 2005
sorry, I thought you had troubles with the image size (instead of the
file size). I think a swf file is always bigger, because it contains
more information? (haven't tried it with layers in my app...)
But that is exactly the reason I opt for a mixed application: for
background/reference map's I want to use images, but for points of
interest (POI's) I want to use a (small) swf files.
Other options are to retrieve xml instead of swf, and use the
information from this xml to put POI's on your movie runtime. Why would
you use swf maps anyway if you do not want to do something with (parts)
of the data?
Richard
Kristjan Annus wrote:
> Hi,
> the link you sent me is usable only from your own computer, so I cant
> see it.
> I'll send you a link from my Flash test application (player 7 required).
> http://www.tartu.ee/bi_kaart/tarkvarastuudio.html
> The opening page swf map file is about 100k in size. The same picture in
> jpg format in the same application is ~33k.
> I use it in another flash movie, but every time when the client is
> zooming a map he has to download about 100-300k
> new map image.
> Kristjan
>> Kristjan,
>> Thanks I think you're right, I can try to make the bitmap (which is
>> actually a call to another OGC mapserver) part of the mapserver
>> mapfile. The mapserver then becomes a cascading mapserver?
>> Don't know how you call the mapserver, but my swf's are exactly the
>> same size as the images I request. I use calls like:
>> "http://localhost/cgi-bin/mapserv.exe?map=fnl.map&mode=map&mapext=-20000%20300000%20300000%20620000&mapsize=300%20300"
>> which returns a flashmovie of 300x300 to me IF you open the movie in
>> the flashplayer. Opening it in a browser shows it indeed 5 times the
>> normal size, but using it in another flashmovie is ok.
>> Richard
>>> I don't know about seting transparent backgrounds if swf output, but one
>>> solution for you is to put your bitmap background image also to your map
>>> file, and create one single swf output for all of your data.
>>> But I have encountered one problem with mapserver FLASH output too,
>>> thats the size of the swf file, when you use OUTPUT_MOVIE=SINGLE option.
>>> In my case it was about 2-5x of the file size of the same output in jpg
>>> format.
>>> Does anybody know is there some way to decrease the swf output file
>>> size?
>>> Kristjan
>>>> Hi List members,
>>>> using the mapserver (two layers) swf/flash output I tried both format
>>>> options:
>>>> FORMATOPTION "OUTPUT_MOVIE=MULTIPLE"
>>>> FORMATOPTION "OUTPUT_MOVIE=SINGLE"
>>>> Using the first one returns an 'index'-swf from which I can get the two
>>>> layer swf's. This results in 'transparent' movies, that is I can show a
>>>> bitmap behind the movie in the flashplayer.
>>>> When using output SINGLE, I receive the right features, but on an
>>>> non-transparant (white) background (without changing any other
>>>> option in
>>>> the mapfile)?
>>>> Question:
>>>> - does anyone know IF it is possible to make the SINGLE output movies
>>>> transparent?
>>>> - If yes, please tell me how?
>>>> - Is there another way, then delving in the mapserver cpp code, to
>>>> influence the code within the mapserver-returned-swf-files (for example
>>>> to influence _root or using _parent references)?
>>>> - Is there other flash-output specific documentation other then: the
>>>> fmv
>>>> flashexample: http://mapserver.gis.umn.edu/user_utilities/fmv.zip?
>>>> Thanks in advance,
>>>> Richard
More information about the MapServer-users
