Getting ESRI to talk to my WMS
Jason Grimes
jgrimes at GI.ALASKA.EDU
Thu Apr 7 19:36:05 EDT 2005
Thanks Jeff,
I didn't specify the "wms_srs" for each layer, just in the map object.
Maybe that is my problem, I will add it in to each layer. Here is my
test map file...
MAP
NAME "GINA_WMS_TEST"
EXTENT -120 38 -76 60
DEBUG on
IMAGETYPE JPG
IMAGECOLOR 255 255 255
STATUS ON
SIZE 600 400
SYMBOLSET
"/usr/local/apache2/htdocs/landman/chameleon/etc/symbols.sym"
SHAPEPATH "/usr/local/apache2/htdocs/WMS"
PROJECTION
"init=epsg:4326"
END
WEB
METADATA
"wms_title" "GINA WMS Test"
"wms_onlineresource"
"https://phobos.gina.alaska.edu/cgi-bin/ginawms?"
"wms_srs" "EPSG:4326"
"wms_abstract" "GINA test WMS server"
END
END
# Start of layers
LAYER
NAME "State_of_Alaska_LL"
STATUS on
DATA "alaska-latlon.shp"
TYPE LINE
TEMPLATE "ttt_query.html"
MAXSCALE 28000000.0
MINSCALE 10.0
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "State_of_Alaska_LL"
"wms_abstract" "Test Alaska state outline in
Lat-Lon projection."
END
CLASS
SYMBOL 0
STYLE
COLOR 212 208 200
END
END
END
END
Jason
On Thu, 2005-04-07 at 14:09, Jeff McKenna wrote:
> Hi Jason,
> I just recently had to set up some data through WMS for some remote
> ArcGIS users. I did not have to include any special parameters/metadata
> that i know of for the WMS server. I did however add optional metadata
> for each layer, such as "wms_srs". I used mapserv version 4.4.1. maybe
> i got lucky :)
> maybe you could include a small test wms-server mapfile (that fails in
> arc) for everyone on the list.
> jeff
> Jason Grimes wrote:
> > Hi,
> > I have set up a WMS service on my local machine. We would like to give
> > ArcGIS users access to the layers but it will not talk to the WMS
> > service. I can get Jump to talk and of course MapServer/Chameleon also
> > talks with the service and no problems. Is there a specific way in
> > which you have to set up the map file? According to my research ArcGIS
> > will not connect up to WMS servers that use any other projection except
> > a Lat/Lon one. I re-projected some of our data using EPSG:4326 and setup
> > a map file with only this projection and ArcGIS will still not talk. It
> > reads the capabilities just fine, but after that it will not contact the
> > server again. I have watched the Apache logs and I can see the
> > capabilities request come through and then nothing. I have also tried
> > other services like the DM Solutions demo here:
> > http://www2.dmsolutions.ca/cgi-bin/mswms_gmap
> > And it works fine with ArcGIS. Maybe one of the DM Solutions guys could
> > point me in the right direction. :) Any help would be most appretiated
> > and if there is a way of having the WMS also work with meter based
> > projections (like Albers) at the same time would be great too. Thanks,
> > Jason
