Getting ESRI to talk to my WMS
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Thu Apr 7 20:37:39 EDT 2005
i would also check your apache logs to see the full request sent by Arc.
jeff
Jason Grimes wrote:
> Thanks Jeff,
> I didn't specify the "wms_srs" for each layer, just in the map object.
> Maybe that is my problem, I will add it in to each layer. Here is my
> test map file...
> MAP
> NAME "GINA_WMS_TEST"
> EXTENT -120 38 -76 60
> DEBUG on
> IMAGETYPE JPG
> IMAGECOLOR 255 255 255
> STATUS ON
> SIZE 600 400
> SYMBOLSET
> "/usr/local/apache2/htdocs/landman/chameleon/etc/symbols.sym"
> SHAPEPATH "/usr/local/apache2/htdocs/WMS"
> PROJECTION
> "init=epsg:4326"
> END
> WEB
> METADATA
> "wms_title" "GINA WMS Test"
> "wms_onlineresource"
> "https://phobos.gina.alaska.edu/cgi-bin/ginawms?"
> "wms_srs" "EPSG:4326"
> "wms_abstract" "GINA test WMS server"
> END
> END
> # Start of layers
> LAYER
> NAME "State_of_Alaska_LL"
> STATUS on
> DATA "alaska-latlon.shp"
> TYPE LINE
> TEMPLATE "ttt_query.html"
> MAXSCALE 28000000.0
> MINSCALE 10.0
> PROJECTION
> "init=epsg:4326"
> END
> METADATA
> "wms_title" "State_of_Alaska_LL"
> "wms_abstract" "Test Alaska state outline in
> Lat-Lon projection."
> END
> CLASS
> SYMBOL 0
> STYLE
> COLOR 212 208 200
> END
> END
> END
> END
> Jason
> On Thu, 2005-04-07 at 14:09, Jeff McKenna wrote:
>>Hi Jason,
>>I just recently had to set up some data through WMS for some remote
>>ArcGIS users. I did not have to include any special parameters/metadata
>>that i know of for the WMS server. I did however add optional metadata
>>for each layer, such as "wms_srs". I used mapserv version 4.4.1. maybe
>>i got lucky :)
>>maybe you could include a small test wms-server mapfile (that fails in
>>arc) for everyone on the list.
>>jeff
>>Jason Grimes wrote:
>>>Hi,
>>>I have set up a WMS service on my local machine. We would like to give
>>>ArcGIS users access to the layers but it will not talk to the WMS
>>>service. I can get Jump to talk and of course MapServer/Chameleon also
>>>talks with the service and no problems. Is there a specific way in
>>>which you have to set up the map file? According to my research ArcGIS
>>>will not connect up to WMS servers that use any other projection except
>>>a Lat/Lon one. I re-projected some of our data using EPSG:4326 and setup
>>>a map file with only this projection and ArcGIS will still not talk. It
>>>reads the capabilities just fine, but after that it will not contact the
>>>server again. I have watched the Apache logs and I can see the
>>>capabilities request come through and then nothing. I have also tried
>>>other services like the DM Solutions demo here:
>>>http://www2.dmsolutions.ca/cgi-bin/mswms_gmap
>>>And it works fine with ArcGIS. Maybe one of the DM Solutions guys could
>>>point me in the right direction. :) Any help would be most appretiated
>>>and if there is a way of having the WMS also work with meter based
>>>projections (like Albers) at the same time would be great too. Thanks,
>>>Jason
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
