Perl API method setProjection doesn t work.
SUBSCRIBE MAPSERVER-USERS Cave
caveeagle at POCHTAMT.RU
Wed Apr 13 03:45:50 EDT 2005
Sorry, I have some problems with perl library for map-script.
Here if I use any projection except lonlat, the output file contains an
empty image. If this projection is set in a cgi-script, everything is
displayed correctly.
If I comment this string:
$map->setProjection('proj=eqc,lat_ts=50,lon_0=80')
The graphic file appears again, but in the standard lonlat projection. In
fact, my problem is that I need to set the projection in perl, instead of
map-file.
Example of perl script:
#!/usr/local/bin/perl -w
use mapscript;
$ENV{MS_ERRORFILE} = "mapError.log"; ### mapscript error log
my $mapname = "/www/allsatwms/allsat.map"; # map-file name
my $map = new mapscript::mapObj($mapname);
if(!$map){warn "New mapObj() error: $mapscript::ms_error->{message}\n";}
$map->{extent}->{minx} = 50;
$map->{extent}->{maxx} = 100;
$map->{extent}->{miny} = 30;
$map->{extent}->{maxy} = 70;
$map->{width} = 1280;
$map->{height} = 1024;
$map->setProjection('proj=eqc,lat_ts=50,lon_0=80');
my $img = $map->prepareImage();
if(!$img){warn "prepareImage() error: $mapscript::ms_error->{message}\n"; }
my $layerAdmin = $map->getLayerByName('admlin');
$layerObj->{status} = $mapscript::MS_ON;
$layerAdmin->draw($map, $img);
$img->save("maptest.gif");
Example of map-file:
MAP
NAME AllSat
EXTENT -180 -90 180 90
SIZE 800 400
UNITS meters
IMAGETYPE gif
TRANSPARENT ON
SHAPEPATH "/www/allsatwms/data"
FONTSET "/www/allsatwms/fonts/fonts.list"
LAYER
NAME "admlin"
GROUP "Admlin"
PROJECTION
"proj=longlat"
END
DATA admlin
STATUS ON
TYPE LINE
CLASS
NAME "admlin"
COLOR 161 33 33
END
END
END
My system is: FreeBSD 5.3-RELEASE
Install swig-1.3.21_1 and perl-5.8.5
Hope for Your help. Best regards,
Efremov Victor, Space Monitoring Information Support laboratory IKI RAN,
Moscow, Russia.
