Does Mapserver-Oracle support labelangleitem?
Fernando Simon
fsimon at UNIVALI.BR
Wed Apr 20 13:06:08 EDT 2005
Hi Paul,
I did some tests using your definition and everthing is wotking.
Here I used this table:
SQL> desc cola_markets;
Name Null? Type
MKT_ID NOT NULL NUMBER
NAME VARCHAR2(32)
SHAPE MDSYS.SDO_GEOMETRY
ANGLE NUMBER
This is the data that I used:
MKT_ID NAME SHAPE(SDO_GTYPE, SDO_SRID, SDO_POINT(X, Y, Z),
SDO_ELEM_INFO, SDO_ORDINATES) ANGLE
90 point_only SDO_GEOMETRY(2001, NULL, SDO_POINT_TYPE(12,
14, NULL), NULL, NULL) 10
And my layer definition: ( I just added the font and type parameters)
layer
connectiontype ORACLESPATIAL
connection 'user/pass at db'
data "shape from (select angle, name, mkt_id, shape from
cola_markets where mkt_id = 90) using unique mkt_id"
name 'test'
TYPE annotation
status off
labelitem "NAME"
LABELANGLEITEM "ANGLE"
class
label
font verdana
type truetype
COLOR 0 0 0
POSITION CC
SHADOWCOLOR 255 255 255
SIZE 12
ANTIALIAS TRUE
ANGLE AUTO
FORCE TRUE
end
end
end
You can see my example using this request:
http://g10novo.cttmar.univali.br/cgi-bin/mapserv?map=/home/apache/mapserv/simmam/simmam2.map&mode=map&imgsize=800+600&mapext=-179.999400+-90.000000+180.000000+83.627400&layers=test
Thanks.
Fernando Simon
Mapserver and Oracle Spatial developer
G10 - Laboratorio de Computacao Aplicada - Brazil
http://g10.cttmar.univali.br - UNIVALI/CTTMAR
Paul wrote:
> I couldn't get labelangleitem working on an oracle spatial
> point-table. In the mapserver list i found some similar posts, but
> nobody replied to previous questions. Is it a known bug? Hass somebody
> found a solution? Is somebody working on it?
> My table is a spatial table with only point geometry
> (geometry,angle,label). The labels show without problems, but they
> don't use the angle:
> LAYER MyLabels
> NAME "street"
> CONNECTIONTYPE oraclespatial
> CONNECTION mo/mo at gk <mailto:mo/mo at gk>
> DATA "GEOMETRY FROM NAST" #srid = null, but also tried;
> geometry from (select...
> STATUS ON
> TYPE ANNOTATION
> LABELITEM "NAME"
> CLASS
> LABEL
> COLOR 0 0 0
> POSITION CC
> SIZE 12
> ANTIALIAS TRUE
> ANGLE AUTO
> FORCE TRUE
> END
> END
> END
> The angle field is in european 12,345 notation, but when i changed it
> to round(angle), the labels still didn't show
> __________________________________________________
> Do You Yahoo!?
> Tired of spam? Yahoo! Mail has the best spam protection around
> http://mail.yahoo.com
