wms capabilities and mapfile scale correspondence
Daniel Morissette
dmorissette at DMSOLUTIONS.CA
Thu Apr 21 10:32:56 EDT 2005
Nuno Gil wrote:
> Hi Tom,
> The problem is that they display different values... :s
> In the map file I have
> MINSCALE 45000001
> MAXSCALE 999999999999
> and in the capabilities file this same layer has
> <ScaleHint min="22450.6" max="4.98903e+08" />
> Any idea why? Maybe a unit related issue? I have UNITS DD set up in
> the MAP element of the map file.
The different values are normal.
MapServer's scale values are what you are used to seeing on paper maps
as scale denominator, e.g. 1:50000, etc.
... and with respect to the scalehint value in WMS capabilities:
> ** (see WMS 1.1.0 sect. 7.1.5.4) The WMS defines the scalehint values as
> ** the ground distance in meters of the southwest to northeast diagonal of
> ** the central pixel of a map. ScaleHint values are the min and max
> ** recommended values of that diagonal.
You can see how we convert from one to the other in function
msWMSPrintScaleHint() in mapwms.c
Daniel
Daniel Morissette dmorissette at dmsolutions.ca
DM Solutions Group http://www.dmsolutions.ca/
